03-02-2013, 19:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: NIGERIA
Member: 1540810 Status: Offline Sonork: 100.1627394 Thanks Meter: 161 | Nokia c2-03 flashing problem Connect phone on selected interface... Core : v1.61 , BB5XG FlashEngine : v4.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm702__07.65.mcusw PPM : rm702__07.65.ppm_m_n CNT : BE73B3A3_rm702__07.65.image_m_n_059D440 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358639047783082 IMEI 2 : 358639047783090 PCcode : 059D440 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358639047783082_2n d_XG213_CRT.rpl ===Flashing [MCU]=== File : rm702__07.65.mcusw Image : rm702__07.65.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:53 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:42 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm702__07.65.ppm_m_n Image : package_m_n.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41DC0000 , Len : 0x0044BE38 Flashing , wait ... Region flash done, time : 00:00:05 ===Flashing [CNT]=== File : BE73B3A3_rm702__07.65.image_m_n_059D440 Image : package_m_n_059D440.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:00:58 Write , Start : 0x424C0000 , Len : 0x00E00000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:03:15 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 07.65 19-09-12 RM-702 (c) Nokia IMEI: 358639047783082 PPM version : V 07.65 19-09-12 RM-702 (c) Nokia M_N Product code: 059D440 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:08 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
