07-08-2014, 11:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Nokia C2 flashing Need Help.. I have a Nokia C2 with user code i use USB and Read its User Code when i entered the code the Mobile Don't accept the code then i go for complete flashing i changed many flash files version 03.99,3.42 but after writing main file the following message occur, Flashing logs will be help full in understanding my problem now what to do? FLASHING LOGS: Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.42.mcusw PPM : rm704__03.42.ppm_q CNT : rm704__03.42.image_q_swhite_059C152 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 357415041783720 IMEI 2 : 357415041783738 PCcode : 059J2R1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357415041783720_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm704__03.42.mcusw Image : rm704__03.42.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:01:21 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash error [ERR_IfCheckResp] Result : 1C001E0201001B00 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:02:37 Connect phone on selected interface... |
07-09-2014, 06:01 | #3 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Thanks Mr' Dzirt But... Quote:
Is it possible that a mobile with phone lock comes with flash IC damage i think set was working fine but only user area was creating problem cause when i read its user code it do not accept it then i went for flashing... any other solution??? B/R Sheraz... | |
07-14-2014, 05:57 | #4 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Still Waiting.... Quote:
No reply from three days the customer is on my neck please team answer my last post that either any mobile with user code can be possibly come with damage flash IC? i need any other working solution........ Waiting for reply.... B/R Sheraz..... | |
07-17-2014, 07:29 | #6 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Flashing logs.... Quote:
May be this can help you better in way about my problem... IMEI 1 : 357415041783720 IMEI 2 : 357415041783738 PCcode : 059J2R1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357415041783720_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm704__03.99.mcusw Image : rm704__03.99.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:01:24 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash error [ERR_IfCheckResp] Result : 1C001E0201001B00 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:02:32 Connect phone on selected interface... Now waiting for your replyyyyy.................. | |
