12-24-2016, 11:56 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: bin/earth/Pakistan...
Member: 1069698 Status: Offline Thanks Meter: 219 | nokia c2 rm 704 flashing error Code: SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-704 Selected Variant : RM-704 SEAP MS SWHITE BENGALI BD Firmware Version : 03.99 Platform Version : Series 40 SSChannel : DC Ok with code 0x04 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-704 exist Prepare done, collect info [Query] : rm704__03.99.image_ms_swhite_059C8L5 , 10.34 MiB [Query] : rm704__03.99.mcusw , 26.22 MiB [Query] : rm704__03.99.ppm_ms , 3.53 MiB [Query] : RM704_059C8L5_03.99_039.vpl , 3.11 KiB Files to download : 4 Total size to download : 40.09 MiB Downloading now, please, wait... [Download] : rm704__03.99.image_ms_swhite_059C8L5 [Download] : rm704__03.99.mcusw [Download] : rm704__03.99.ppm_ms [Download] : RM704_059C8L5_03.99_039.vpl Verify files now ... [Verify Ok] : rm704__03.99.mcusw [Verify Ok] : rm704__03.99.ppm_ms [Verify Ok] : rm704__03.99.image_ms_swhite_059C8L5 All done, all files were downloaded! Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.99.mcusw PPM : rm704__03.99.ppm_ms CNT : rm704__03.99.image_ms_swhite_059C8L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359337045696047 IMEI 2 : 359337045696054 PCcode : 059J4Z7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\nokia firmware n tools\InfinityBox_install_BEST_v2.21\BEST\Backup\Cert\359337045696047_2nd_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm704__03.99.mcusw Image : rm704__03.99.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:29 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x6C69 ===Flashing [PPM]=== File : rm704__03.99.ppm_ms Image : package_ms.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:19 Write , Start : 0x41BC0000 , Len : 0x0035045C Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0xE366 ===Flashing [CNT]=== File : rm704__03.99.image_ms_swhite_059C8L5 Image : package_ms_swhite_059C8L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x421C0000 , Len : 0x00A20000 Flashing , wait ... Region flash error [ERR_IfCheckResp] Result : 1C001E0201001B00 Error... -> Check cable, flashfile, try again from this file |
12-25-2016, 14:45 | #6 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, please download a higher version of model available, then select dead mode and repeat process again, if you have backup previuosly saved, untick option and repeat process again... you will be ok.... Best Regards Shensohau |
12-25-2016, 15:16 | #8 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Did you try with a diferent product code??? even if you try after flash, reset factiry settings and then check, is security on phone ok??? Best Regards Shensohau |
12-26-2016, 02:02 | #11 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, some phone firmwares blocked on startup if unlock counter is 0, please check that first or it is hardware issue related to some simcard ways... Best Regards Shensohau |
12-26-2016, 07:13 | #12 (permalink) | |
Member: 1069698 Status: Offline Thanks Meter: 219 | Quote:
Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C2-00 Software ver : V 03.99 03-04-12 RM-704 (c) Nokia IMEI 1 : 359337045696047 IMEI 2 : 359337045696054 XappVer : 000008CA PPM : V 03.99 03-04-12 RM-704 (c) Nokia A CNT : Content: a_059L7K9 V 03.99 03-04-12 RM-704 (c) Nokia Product SN : 566C527AH Product code : 059J4Z7 Base Prd.code: 059B9Q6 Module code : 0204689 Long Prod.SN : 0 Hardware info======= HWID : 1000 Battery: 3845 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 359337045696047 IMEI spNet : 3A 95 33 07 54 96 06 04 IMEI svNet : 33 95 33 07 54 96 06 14 F4 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 333B60B075CA6804 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Read and Check phone data... ---------------------- RAP_BOOT: 0000000000000000 RAP_PUB: 0000000000000000000000000000000000000000 CMT_ROOT: 00000000000000000000000000000000 RAP_PAPUB: 0000000000000000000000000000000000000000 ---------------------- Live Test Ok! ---------------------- CNT sector : 128 kb ------------------------ CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Last edited by umr_butt; 12-26-2016 at 07:21. | |
