10-01-2014, 13:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | Nokia C3 RM-614 Read phone book ?????? i want extract phone book from Nokia C3 can't enter to local mode, i do read rpl,it read the phone ,but can't bootup to read info. just i listen usb coonnect/disconnect sound ..... Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000A25C9E97997D46AC29F0D105215CFC ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: Reading certificates... Reading NPC certificate... IMEI : 353760048214318 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... - > Phone not found... - > CertRead failed : phone was not bootup - > Connection/SW/HW problem, try bootup manually NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353760048214318_CR T.rpl Phone disconected! Connect phone on selected interface... plllllllllllz how to solve, it's important to read the phonebook |
10-01-2014, 14:15 | #3 (permalink) | |
Member: 382783 Status: Offline Thanks Meter: 124 | Quote:
Wawwww Great Tool & Gooood work from your team. Thanks Mr Dzirt For Hellllp,Thanks veeeeeeeery much. plllllllllllz Mr Dzirt can i contact you at Skype or sonork or .... if i need help ? | |
10-01-2014, 18:17 | #5 (permalink) |
Member: 382783 Status: Offline Thanks Meter: 124 | OK Thanks again for help,this log Dooooooooooooooone!!! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000A25C9E97997D46AC29F0D105215CFC ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: phone is in flash mode Reading NPC certificate... IMEI : 353760048214318 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353760048214318_CR T_2nd.rpl Will read flash content now... Flash IC Size : 128 MB Read done , 123 MB has read FullFlash saved to : 353760048214318_full.bin ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Done!!! Connect phone on selected interface... Processing S40 [XG618/BB5] mode Scan image... Disc found, Size: 73M Search... Miriel detect phonebook type now ... Data proceed ok... CSV file saved to .\Phones_Data\Readout\353760048214318_full.csv 317 records are found S40 PhoneBook saved to : 353760048214318_full.s4pb Done!!! |
10-02-2014, 09:02 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Yes, right. Now you have csv/vcf files for sync to other phone and s4pb for write back after phone repair. Just use "Write PhoneBook" and select 353760048214318_full.s4pb as file. |
