04-17-2015, 20:00 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Nokia E5 Is It Possible To DOWNGRADE ? Customer Want Use Arabic Language In It So I Searched Default Firmware By Product Code, Unfortunately I Found DOWNGRADE Firmware. Code: Connect phone on selected interface... Core : v2.04 , BB5XG FlashEngine : v9.9 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_101.003_prd.core.fpsx PPM : rm632_101.003_25.01_MEA_A_prd.rofs2.fpsx PPM2 : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 18A002067DDA0344247FF8CA4DA445A77171AF76 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 35741XXXXXXXXXX Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35741XXXXXXXXXX_CRT.rpl === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ADL: Close_Session Content: 000300000000090000000900000000 ADL: Reboot Elapsed: 00:00:40 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
04-17-2015, 20:08 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | downgrade is long story ...... just use the latest firmware and only replace the ppm (language file) from downgrade version then everything will be fine Zubair ZK MObiles |
The Following User Says Thank You to zubairok For This Useful Post: |
04-23-2015, 13:31 | #4 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, I Write "PPM Only" File Arabic Language Come But Internet Browser Not Work So Decided To "FullFlash" Then After Flash Cellphone Dead. Code: Connect phone on selected interface... Core : v2.04 , BB5XG FlashEngine : v9.9 Selected FlashSettings : PPM only Check FlashFiles, Please, wait... Files Set for Flashing : PPM : rm632_101.003_25.01_MEA_A_prd.rofs2.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 18A002067DDA0344247FF8CA4DA445A77171AF76 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 35741XXXXXXXXXX Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35741XXXXXXXXXX_CRT_2nd.rpl ===Flashing [PPM]=== Erase : Processing rm632_101.003_25.01_MEA_A_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm632_101.003_25.01_MEA_A_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 221 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000009 / 00000009 / 00000000 ADL: Close_Session Content: 000300000000090000000900000000 ADL: Reboot Flashing done! Total flash time : 00:00:08 Reboot phone now... Afterflash not selected, skip Done! Phone disconected! Connect phone on selected interface... Elapsed: 00:00:30 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:02 Set phone in Normal mode... Restarting... Done! FullFlash Log. Code: Connect phone on selected interface... Core : v2.04 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_101.003_prd.core.fpsx PPM : rm632_101.003_25.01_MEA_A_prd.rofs2.fpsx PPM2 : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm632_101.003_U010.000_prd.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 18A002067DDA0344247FF8CA4DA445A77171AF76 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 35741XXXXXXXXXX Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35741XXXXXXXXXX_CRT_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm632_101.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_101.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 433 blocks TIME : Write time : 00:00:14 MCU Write done ADL: Request programm status NAND status : 00000009 / 00000009 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_101.003_25.01_MEA_A_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_25.01_MEA_A_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 221 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000009 / 00000009 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000009 / 00000009 / 00000000 ===Flashing [CNT]=== Erase : Processing rm632_101.003_U010.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_101.003_U010.000_prd.uda.fpsx Total writen 97 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000009 / 00000009 / 00000000 ADL: Close_Session Content: 000300000000090000000900000000 ADL: Reboot Flashing done! Total flash time : 00:00:37 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:03:03 Now Cellphone Is Only Vibrate. |
04-23-2015, 13:49 | #6 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, Actually I'm Flashing Very Few Nokia Cellphone. That's Why Don't Know Much About It. I Expected If Cellphone Dead So Definitely You'll Help Me, So Now Forgive Me & Help Me Please. Give Me Video Link For How To Downgrade. |
04-23-2015, 13:51 | #7 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | In link on post #3 of this thread all explained. Here can find link to ENO file : http://forum.gsmhosting.com/vbb/f641...flash-1936472/ |
04-23-2015, 16:38 | #8 (permalink) |
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | my dear friend i didn't told you to flash only ppm you have you use all new files with old ppm MCU latest PPM old UDA Image Latest then tell me result Zubair |
04-25-2015, 20:12 | #10 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, When I'm Try To "Read RPL" It's Show Error. Or Is It Okay ?. Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 18A002067DDA0344247FF8CA4DA445A77171AF76 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: Reading certificates... Reading NPC certificate... IMEI : 35741XXXXXXXXXX Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000090000000900000000 ADL: Reboot Wait, reconneting... - > Phone not found... :( - > CertRead failed : phone was not bootup - > Connection/SW/HW problem, try bootup manually NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35741XXXXXXXXXX_CRT_2nd.rpl Phone disconected! Connect phone on selected interface... |
04-25-2015, 20:47 | #11 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Which Is The Correct & Easy Way ?. Platforms : By ONLY USB cable can be done with : RAPU11 - E5, and others. Actions : 1st step : RPL backup, PM backup, PP backup 2nd step : Erase FLASH 3rd step : Flash needed FW version 4th step : RPL restore 5th step : Repair SDD if needed, do Local SX4 + Upload PM 6th step : Factory sets, edit production data, run phone Or This Way ?. Full Backup Erase Flash ENO Full Flash Write RPL PM File (PM Operations) PP File (Product Profile) |
04-26-2015, 16:40 | #13 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, I Followed Software Process, But The Problem Not Solve. If I Write Plain RPL So Cellphone Power On But IMEI 12345610654321. If I Write Original RPL So Cellphone Power On With Nokia Logo Then Off & Restart With Blank LCD. What Should I Do Now ?. |
05-08-2015, 18:55 | #15 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, How To "REPAIR SDD" ? Code: Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 18A002067DDA0344247FF8CA4DA445A77171AF76 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Seek file for this phone.... ----------------------------- - > RPL file found for this phone! - > NPC Found in : 35741XXXXXXXXXX.rpl Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! ----------------------------- Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000090000000900000000 ADL: Reboot Wait, reconneting... Check phone mode... Phone already in Test mode, skip change... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Product Code Update : 059J708 SDD Key status : SDData Damaged!!!!! :( - > Do REPAIR SDD , Local SX4 if needed CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 WMDRM_PD key sent... Ok Done! Repair SD procedure started... Code: Phone Imei: 35741XXXXXXXXXX - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 18A002067DDA0344247FF8CA4DA445A77171AF76 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B Fetching data, wait... Error while send data, cable/battery problem Fetching failed! Connect phone on selected interface... UFSx error, reconnect and try again... Repair fail...! Connect phone on selected interface... |
