08-10-2013, 09:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 985391 Status: Offline Thanks Meter: 12 | Nokia E63 nokia logo and stuck i flash latest firmware but same this my log Code: Opening Connection... Device Location: 00000011 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Opening Connection... Device Location: 00000011 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.67 , BB5XG FlashEngine : v5.5 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm437_510.21.010_prd.c00 PPM : rm437_510.21.010_prd.v42 CNT : rm437_510.21.010.36U APE : sofie_erase_y_drive.fpsx CNT3 : RM437_ENO_008.07.45_100.71.952.a018.fpsx CRT308 Backup Created Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0F90010C74A30052F7A4CAC7728F70E263E5F707 CMT MODE ID : 00 CMT R_HASH : C70CB07324056BC66A824347F40DB2D5 CMT ROM ID : 4B9B75103E691FF8 - > Change Protocol : NEW Using NEW Flashing Protocol CMT : Sending 2nd loader... Use RAPIDOv11_2nd.fg , Rev : 2.0 Ver : 9.48.0 CMT Loader sent, Boot Ok Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine CMT Flash ID : 00400020 < ST => M39BORBOAD FLIC : 00400020 , NAND , CMT Sending Algo... Use RAPIDOv11_XSR17_alg.fg , Rev : 2.0 Ver : 9.48.0 Finalize done, Algo sent! Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine PapubKeysReq : D9C25399C696B8549EDCDB1497A950B3A20DDFB6E0 Boot done! CMT : Read NPC certificate... IMEI : 000000000000000 CMT : Read CCC certificate... CMT : Read HWC certificate... CMT : Read VARIANT certificate... Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0F90010C74A30052F7A4CAC7728F70E263E5F707 CMT MODE ID : 00 CMT R_HASH : C70CB07324056BC66A824347F40DB2D5 CMT ROM ID : 4B9B75103E691FF8 - > Change Protocol : NEW Using NEW Flashing Protocol CMT : Sending 2nd loader... Use RAPIDOv11_2nd.fg , Rev : 2.0 Ver : 9.48.0 CMT Loader sent, Boot Ok Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine CMT Flash ID : 00400020 < ST => M39BORBOAD FLIC : 00400020 , NAND , CMT Sending Algo... Use RAPIDOv11_XSR17_alg.fg , Rev : 2.0 Ver : 9.48.0 Finalize done, Algo sent! Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine PapubKeysReq : D9C25399C696B8549EDCDB1497A950B3A20DDFB6E0 Boot done! SC : StoreCert Ok Partitioning.... Partitioning Ok... Erase : Processing rm437_510.21.010_prd.c00 Init Erase Mode Ok Found 4 data types Erasing Data.... Erase area : 0x00040000 - 0x007FFFFF , CMT , NAND Erase area : 0x00A00000 - 0x0759FFFF , CMT , NAND Erase area : 0x0F1C0000 - 0x0F8BFFFF , CMT , NAND Erase Ok... Erasing Partition.... Partition 0x0B Erase Ok... Erasing Partition.... Partition 0x09 Erase Ok... Erasing Partition.... Partition 0x0A Erase Ok... TIME : Erase time : 00:00:01 Write : Processing rm437_510.21.010_prd.c00 Init Write Mode Ok CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS*CORE] CMT: Writing Hash CERT [SOS+ROFS] Total writen 521 blocks TIME : Write time : 00:05:02 PrReq : NAND , 000300000000010000000100000000 Erase : Processing rm437_510.21.010_prd.v42 Init Erase Mode Ok Found 2 data types Erasing Data.... Erase area : 0x05420000 - 0x0759FFFF , CMT , NAND Erase Ok... Erasing Partition.... Partition 0x09 Erase Ok... TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_prd.v42 Init Write Mode Ok CMT: Writing Hash CERT [SOS+ROFX] Total writen 210 blocks TIME : Write time : 00:02:08 PrReq : NAND , 000300000000010000000100000000 ConvertImage: Processing rm437_510.21.010.36U ConvertImage: Page Size is 128K, no need convert Erase : Processing rm437_510.21.010.36U Init Erase Mode Ok Found 1 data types Erasing Partition.... Partition 0x08 Erase Ok... TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010.36U Init Write Mode Ok Total writen 181 blocks TIME : Write time : 00:01:50 PrReq : NAND , 000300000000010000000100000000 Erase : Processing sofie_erase_y_drive.fpsx Init Erase Mode Ok Found 1 data types Erasing Data.... Erase area : 0x0F020000 - 0x0F1BFFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 Write : Processing sofie_erase_y_drive.fpsx Init Write Mode Ok Total writen 0 blocks TIME : Write time : 00:00:00 PrReq : NAND , 000300000000010000000100000000 Erase : Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx Init Erase Mode Ok Found 1 data types Erasing CRT.... Erase CRT : SOS*ENO , CMT Erase Ok... TIME : Erase time : 00:00:00 Write : Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx Init Write Mode Ok CMT: Writing Hash CERT [SOS*ENO] Total writen 15 blocks TIME : Write time : 00:00:07 PrReq : NAND , 000300000000010000000100000000 Switch jaf to FBUS... FbusMode set Ok Phone connected Reading Phone Info.... Connected phone - Nokia E63 Software Info: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia IMEI: 12345610654321? Product code: Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... AfterFlash operations done ;D Flashing done Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
08-10-2013, 10:36 | #3 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
About phone - try make FS format first. And factory set few times. Flash Blank PMM - BEST/phdata/stuff/ Reflash phone again. | |
