05-21-2014, 11:17 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2076930 Status: Offline Sonork: 100.1609967 Thanks Meter: 42 | nokia flash 108 onely light blinging? after flash same condition (flash with same P.code file) please any guide for mee flash log here Connect phone on selected interface... Core : v1.89 , MTKx FlashEngine : v3.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 - > MODE : Language Change Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 152 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E4BA57DAFD7A0089D617930F99547825 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.10.04.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.10.04.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 3 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 Write : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:25 Reboot phone Ok Connect phone on selected interface... |
05-21-2014, 12:01 | #3 (permalink) |
Member: 2076930 Status: Offline Sonork: 100.1609967 Thanks Meter: 42 | read log here phone now contact service card found: registered to: Connect phone on selected interface... Core : v1.89 , MTKx FlashEngine : v3.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 152 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E4BA57DAFD7A0089D617930F99547825 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_20.06.11 SecureDecrypt : RM-944_VIVA_eMP_20.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 Write : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_20.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_MR_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_MR_APAC_VN_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_MR_APAC_VN_eMP_20.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:06 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 20.06.11 00-00-00 RM-944 IMEI: 123456789012345 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : MR Product code: 059S7R9 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok |
05-21-2014, 12:25 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It is NOT read log. I ask for Read log. By the way I see - it have destroyed security. Via some chinese tool. |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-21-2014, 12:42 | #5 (permalink) |
Member: 2076930 Status: Offline Sonork: 100.1609967 Thanks Meter: 42 | sory .. read flash log ............... card found: registered to: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or boot from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 152 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E4BA57DAFD7A0089D617930F99547825 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Read done IMEI : 3599740575***** CBR BBSN : E4BA57DAFD7A0089D617930F99547825 PHB BBSN : E4BA57DAFD7A0089D617930F99547825 [CBR] : CBR is Ok, match with BB SN. Phone Security is Alive SimLock : Open (Not Locked) File Saved to : 3599740575*****_MTK.bin Security [RPL] Saved to : 3599740575*****.mtsec Read Done! Connect phone on selected interface... Last edited by vsy; 05-21-2014 at 12:49. |
05-22-2014, 05:54 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Due dumps it seems Ok, but in log IMEI is 123345... Did you get phone in that condition? Now try make REPAIR MAUI (file on support) After Write RPL After - Reflash with latest FW, not matter PC , just latest. |
05-22-2014, 15:08 | #10 (permalink) | |
Member: 2076930 Status: Offline Sonork: 100.1609967 Thanks Meter: 42 | Quote:
card found: S/N 4B9A:0122 registered to: [email protected] Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 140 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E4BA57DAFD7A0089D617930F99547825 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Boot Ok [MAUI] : MAUI seems as Alive, SDS Info exists Get settings... Erase region , wait ... Write region , wait ... Write : RM-944_110111_MAUIFIX_m62.lbl All done! Reflash phone now with regular firmware! Finishing session All done! Write RPL log:: card found: S/N 4B9A:0122 registered to: [email protected] Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 152 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E4BA57DAFD7A0089D617930F99547825 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Boot Ok Get settings... SDS OFF : 0x003F4000 SDS LEN : 0x0000C000 [INFO] : Plain RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Write : 359974057579941.mtsec Encrypt Done, Now Re-connect power/cable! Wait for phone... Phone found! [ 152 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E4BA57DAFD7A0089D617930F99547825 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Boot Ok Get settings... Write : 359974057579941_enc.mtsec [ERROR] : [ERROR] : Security restored All done! Connect phone on selected interface... Reflash with latest FW log:: card found: S/N 4B9A:0122 registered to: [email protected] Connect phone on selected interface... Core : v1.89 , MTKx FlashEngine : v3.0 Verify files ... MAUI : RM-944_ROM_eMP_21.00.11 VIVA : RM-944_VIVA_eMP_21.00.11 LANG : RM-944_LANG_PACK_ROM_ME_eMP_21.00.11 CUST : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_21.00.11 JMPT : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_21.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 152 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E4BA57DAFD7A0089D617930F99547825 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_21.00.11 SecureDecrypt : RM-944_VIVA_eMP_21.00.11 SecureDecrypt : RM-944_LANG_PACK_ROM_ME_eMP_21.00.11 SecureDecrypt : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_21.00.11 SecureDecrypt : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_21.00.11 OVRLP : 000069B900000001 PHPID : Bree.11.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_21.00.11 Write : RM-944_LANG_PACK_ROM_ME_eMP_21.00.11 Write : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_21.00.11 Write : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_21.00.11 Write : RM-944_VIVA_eMP_21.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_21.00.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_ME_eMP_21.00.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_21.00.11 [VERIFY] DONE : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_21.00.11 [VERIFY] DONE : RM-944_VIVA_eMP_21.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:07 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 21.00.11 00-00-00 RM-944 IMEI: 123456789012345 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : ME Product code: Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok phone now cotact service please help | |
05-22-2014, 15:47 | #11 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Aha, I see now : Code: Get settings... Write : 359974057579941_enc.mtsec [ERROR] : [ERROR] : Security restored I will try make some repair file tomorrow, if not help - it just a spareparts, due IC damage. |
05-23-2014, 12:15 | #12 (permalink) | |
please help me............................... | |
05-24-2014, 08:32 | #13 (permalink) | |
please need your help | |
05-26-2014, 08:12 | #15 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It is brick anyway , as I told - it have some kind of bad block in security area , I had check all possible way to make same phone - it should be damaged on HW level. |
