09-21-2016, 16:29 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh Age: 30
Member: 1034743 Status: Offline Sonork: 100.1619212 Thanks Meter: 193 | nokia Lumia 540 Flashing failed help or solutin,, Code: Battery Level : 90% RPMB Provision Status Code : 0x0101 Device RAM size : 1024 MiB Device have ATRP (AntiTheft) system! Backup to RAM Ok! FFU : RM1141_02074.10000.15174.44001_RETAIL_prod_signed_1007_02250F_000-66_MV.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted :) Perform Data Partition Erase Error : 06 : Data Partition Not Found! Seems as damaged Will Fix partitions by flash whole image Sending FFU Header CertData Header sent , accepted :) Skip Data Partition Erase Sending FFU Payload Data... Error, stop at : 0x0003 , reason : NO ACK !!! Connection broken due some HW reasons ( like empty battery or cable ) or drivers problem! Red Light :( Error during flashing! [Info] : Check previous message carefully , follow given advises [Info] : Recommended to not power off device, if it shows "RED SCREEN" [Info] : After problems will be fixed - tick "Recovery" and repeat flashing again! Connect phone on selected interface... not flashing ,,, |
09-21-2016, 16:31 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. What you mean under "not flashing" ? Same log/result? It stop at first percent? Make sure your drivers is updated. Better try flash on different PC. There was some rare problem with motherboards on Intel platform on PC side. |
09-21-2016, 16:42 | #3 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: Sheikhupura, Punjab, Pakistan
Member: 2242730 Status: Offline Thanks Meter: 42 | Quote:
this emmc fault try to repair emmc. | |
