Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 12-28-2015, 21:43   #1 (permalink)
Member: 224075
Thanks Meter: 69
nokia lumia 635 test mode not detected by best
other lumia phones like 820 , 1250 working good and unlock done by same drivers and same compuers and same usb
635 detected in normal mode and read info ok but when i put it to test mod not detected
i used drivers from infinty support erea Lumia_WP8x_Drivers
whats probelm and how i can unlock this phone ??
Old 12-29-2015, 06:48   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
What device manager detect in Universal Serial Bus , when Lumia in Test Mode?
Old 12-29-2015, 09:55   #3 (permalink)
Member: 224075
Thanks Meter: 69
Universal Serial Bus Devices
>>Lumia USB Connectivity
Old 12-29-2015, 18:47   #4 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Same Situation my Bro, phone not detected in test-mode!
Old 12-29-2015, 21:28   #5 (permalink)
Member: 224075
Thanks Meter: 69
wheres best supporter to advice what to do ???
Old 12-30-2015, 05:35   #6 (permalink)
JayDi's Avatar
Member: 462970
Here. I have no idea what to advise, because with provided info can't see the problem.
There is SHOULD BE 2-3 devices. Not one.
I need their VID/PID as well ( can check them in device properties )
Old 12-30-2015, 11:30   #7 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Phone detected and My error number is [0060] from server!
Old 12-30-2015, 12:13   #8 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
sometimes i fix the issue by
1.use latest version
2.install lumia pack
3.install zune package
4.make hard reset the phone
5.change eno
6.make flashing with latest firmware
but it is so hard
to do the job
now my 1 phone has critical problem
unable to find a bootable option. Rm-975
i think team should give us special driver to fix the issue
and we know infinity team always give best to us
so our exception is high to our team
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post:
Old 12-30-2015, 12:23   #9 (permalink)
JayDi's Avatar
Member: 462970
It not related to drivers at all.
5.change eno
but it is so hard
to do the job
Zune has nothing to do with WP8x drivers at all.
"Unable to find" - check over search. If BootRepair not help - then probably, eMMc is read only.
Old 12-30-2015, 12:30   #10 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
boot repair success
but same issue
customer just give me to unlock.
the unlocking time is gives error with infinity lumia credit.
then i seen. from server credit is eaten
then i plan to make flash and unlock again
because a lot of times i got success to unlock after flashing and write same version eno.
now i m still confused
what was my mistake.
i m sorry to say.i have no logs of operation to give you
Old 12-30-2015, 12:33   #11 (permalink)
JayDi's Avatar
Member: 462970
In your case then - "Unable to find" - eMMC problem.
Repair it first.
Old 12-30-2015, 15:52   #12 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Repair it first.
In My Case Boss, any options?????
Old 12-30-2015, 16:54   #13 (permalink)
JayDi's Avatar
Member: 462970
Just check SW messages and try check explanations of them.
Old 12-30-2015, 18:42   #14 (permalink)
Member: 224075
Thanks Meter: 69
problem solved by eno file
thanks
Old 12-31-2015, 07:57   #15 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
Repair it first.
i unbrick my mobile with my lovely best
Connect phone on selected interface...
Collect Info...
Unable get Device Security Status, trying skip
Unable get Device RKH, Unable continue :(
Charge battery, check cable
Collect Info...
Setting Application
Setting Secure
Collect Info...
=== Nokia Flash App info :
Protocol Version        : 2.28
Protocol Implementation : 2.53
=== Phone Initial info :
Phone RMxxx ID : RM-975
Phone Model ID : Nokia.MSM8926.P6112.1.1
Phone Model PC : 059V6W5
Phone IMEI     : 356485060782730
=== eMMC info :
eMMC Vendor : Toshiba
eMMC CID : 0011
eMMC Size : 7456 MiB
=== Security Initial info :
Security Status   : 010100000101
Secure Boot : Enabled
Secure eFUSE : Enabled
JTAG : Disabled
RDC Key : Not Present (Retail)
UEFI SBoot : Enabled
SecHW Key : Exists
Device RootKey    : B2F6BECAAED8735388C21591177EDEBE44E5D762
=== Other info :
SD present        : False
Full Check skipped , will be checked by ImageSignature
Battery Level : 55%
Battery Level enough to flash
FFU : 42984D4D_RM975_02173.00000.15154.50006_RETAIL_prod_signed_1050_025C52_AIO-US.ffu
Flashing FFU
Sending FFU Header CertData
Header sent , accepted :)
Perform Data Partition Erase
Erase done
Sending FFU Payload Data...
Finishing flashing
Flashing done!
Green Light :)
Image Sent, processing PostFlash
Make Factory Set : Ok
Restore RAMBkp : Ok
PostFlash Finished
Total flash time : 00:05:41
Rebooting
Phone found!
WP8x Nokia Phone detected
Read info... Ok
now need same version eno file to unlock the phone.
here only 2 file
pls give me same version or comparable eno file
Page generated in 0.21366 seconds with 8 queries
