08-23-2014, 18:17 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | N900 User code so i flash it with emmc also but code not gone . before flash set dont have any code . any way to remove this or bypass this |
08-24-2014, 05:33 | #3 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | i have a question in my mind . according to instruction If Device ask code on start - Flash with SW 10 - ONLY RootFs i flash the phone with latest ver. 21. . so now sw 10 rootfs damage the phone or not plz tell me. i flash rootfs in ver 21 but same condition . |
08-24-2014, 05:37 | #4 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
do as dzirt sir said any way flash only rootfs with v 10 then set will not ask password in startup but not remove or change password go to best support and you will find what u want.. do u have original best or just using crack | |
08-24-2014, 06:05 | #6 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | problem solved Check : Processing RX-51_2009SE_10.2010.19-1_PR_COMBINED_MR0_ARM.bin ========== FW APE version : 10.2010.19-1 FW CMT version : rx51_ICPR82_10w08 FW PRx release : PR_1.2 FW Region info : GLOBAL FW Region ver : MR0 KERNEL version : 2.6.28-20101501+0m5 ========== Check : File Is Ok ! Core : v1.95 , Tablet FlashEngine : v5.4 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2104 NOLO : 01/0E/14 SWVer: RX-51_2009SE_21.2011.38-1.002_PR_002 Device mode : Production mode ========== FW APE version : 21.2011.38-1.002 FW PRx release : PR_1.4 FW Region info : USA FW Region ver : 002 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing APE part File : RX-51_2009SE_10.2010.19-1_PR_COMBINED_MR0_ARM.bin Processing : rootfs , RX-51_2009SE_10.2010.19-1_PR_MR0 RootFs flash Ok Executing PostFlash : Reboot Done! Elapsed: 00:00:23 Connect phone on selected interface... topic close |
08-24-2014, 06:24 | #7 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | to completely remove/ reset password http://forum.gsmhosting.com/vbb/f641...d-how-1406166/ |
