Nokia lumia n9 flashing error Hi Best team I am suffering a lot to flash the nokia lumia N9 It gives error but tried to flash with different upper files no success here is the log: Connect phone on selected interface... Check : Processing 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin ========== FW APE version : 40.2012.21-3.480.04.1 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 480 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Core : v1.76 , Tablet FlashEngine : v4.5 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454 Device mode : Production mode ========== FW APE version : 40.2012.21-3.454.6 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 454 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... MKII mode init Ok Device : RM-696 HW build : 1603 Bat.level : 100 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok MKII Set : Host Protocol set to 108 MKII Set : CMT Verify On MKII Set : Perform RFS On MKII Set : eMMC preserve On ---Processing MCU image--- Processing File : 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin MKII : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 00 MKII : Flashing... MKII : Finalizing... cert-sw Flash done MKII : ERROR_SECURITY! PHONE REPORT DOWNGRADE TRY! Receiving error list... Last Errors : bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed Downgrade disallowed (1354187757) [Pipe 0] Finishing in error state with status 10 Flashing failed More info in Last Error Log Elapsed: 00:00:19 Connect phone on selected interface... Core : v1.76 , BB5XG FlashEngine : v7.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : Flashing phone now... Rules accepted for : Unknown Generation Check files done... -> SWversion check skipped : Dead mode selected -> Sorry, can't flash it now - please send report to support Also flashed with this file: Check : Processing 670D5405_DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin ========== FW APE version : 40.2012.21-3.468.1 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 468 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Core : v1.76 , Tablet FlashEngine : v4.5 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454 Device mode : Production mode ========== FW APE version : 40.2012.21-3.454.6 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 454 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : 670D5405_DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... MKII mode init Ok Device : RM-696 HW build : 1603 Bat.level : 100 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok MKII Set : Host Protocol set to 108 MKII Set : CMT Verify On MKII Set : Perform RFS On MKII Set : eMMC preserve On ---Processing MCU image--- Processing File : 670D5405_DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin MKII : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 00 MKII : Flashing... MKII : Finalizing... cert-sw Flash done MKII : ERROR_SECURITY! PHONE REPORT DOWNGRADE TRY! Receiving error list... Last Errors : bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed Downgrade disallowed (1354187757) [Pipe 0] Finishing in error state with status 10 Flashing failed More info in Last Error Log Elapsed: 00:00:13 Connect phone on selected interface... please best team help me to revive my phone yuo can give me the link for the appropriate file Thank you! |
Please Best Team Help me to revive my phone Thank you! |
I see some problems with N9 FW's in Navimanager. Let me fix it and find correct fw for your phone. 1-2 hours. |
Thank you very much Dzirt The file u gave is working fine My phone is alive and here is the log registered to: msajum Connect phone on selected interface... Check : Processing 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin ========== FW APE version : 40.2012.21-3.454.6 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 454 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Core : v1.76 , Tablet FlashEngine : v4.5 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454 Device mode : Production mode ========== FW APE version : 40.2012.21-3.454.6 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 454 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... MKII mode init Ok Device : RM-696 HW build : 1603 Bat.level : 100 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok MKII Set : Host Protocol set to 108 MKII Set : CMT Verify On MKII Set : Perform RFS On MKII Set : eMMC preserve On ---Processing MCU image--- Processing File : 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin MKII : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 00 MKII : Flashing... MKII : Finalizing... cert-sw Flash done MKII : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 MKII : Init pipe 01 MKII : Flashing... MKII : Finalizing... kernel Flash done MKII : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454 MKII : Init pipe 02 MKII : Flashing... MKII : Finalizing... rootfs Flash done MKII : Sending config for [cmt-2nd] -> Ver T : RM-696 MKII : Init pipe 03 MKII : Flashing... MKII : Finalizing... cmt-2nd Flash done MKII : Sending config for [cmt-algo] -> Ver T : RM-696 MKII : Init pipe 04 MKII : Flashing... MKII : Finalizing... cmt-algo Flash done MKII : Sending config for [cmt-mcusw] -> Ver I : 9.2.2011.51 -> Ver T : RM-696 MKII : Init pipe 05 MKII : Flashing... MKII : Finalizing... cmt-mcusw Flash done MKII : Sending config for [xloader] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 06 MKII : Flashing... MKII : Finalizing... xloader Flash done MKII : Sending config for [secondary] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 07 MKII : Flashing... MKII : Finalizing... secondary Flash done Switch : OSSO UART+USB Version : DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454 Update SW release Ok Done! Elapsed: 00:02:48 Connect phone on selected interface... |
I fixed Navi base for PR regions, so, in v1.77 you can find all PR-xxx firmwares. |
Take and use! |
