Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 12-04-2013, 06:59   #1 (permalink)
Member: 714291
Thanks Meter: 38
Nokia lumia n9 flashing error
Hi Best team
I am suffering a lot to flash the nokia lumia N9
It gives error but tried to flash with different upper files no success
here is the log:
Connect phone on selected interface...
Check : Processing 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin
FW APE version : 40.2012.21-3.480.04.1
FW CMT version : 9.2.2011.51
FW PRx release : PR_1.3
FW Region info : BRANDED TO CARRIER
FW Region ver : 480
KERNEL version : 2.6.32-20121301+0m8
Check : File Is Ok !
Core : v1.76 , Tablet FlashEngine : v4.5
Insert cable in to powered OFF phone! (Ignore if phone Connected)
Waiting for NOLO...
Connect in NOLO mode Ok!
Phone Info :
Type : RM-696 , HWRev : 1603
NOLO : 01/06/23
SWVer: DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454
Device mode : Production mode
FW APE version : 40.2012.21-3.454.6
FW Region ver : 454
Read info Ok
=== SW version Check ====
Ok [Reflashing or Upgrade]
Processing APE Boot...
File : 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin
Processing : ape-algo
APE Algorithm boot Ok
Reopening the connection...
MKII mode init Ok
Device : RM-696
HW build : 1603
Bat.level : 100
SW release : (empty)
Protocol : 108
UPDAPP ver : 1.7.2
Upd/Dev PT : 3 , 3
FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw
Last errors : bb5_rdc_cert_read failed
Code Match Ok
HW match Ok
MKII Set : Host Protocol set to 108
MKII Set : CMT Verify On
MKII Set : Perform RFS On
MKII Set : eMMC preserve On
---Processing MCU image---
Processing File : 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin
MKII : Sending config for [cert-sw]
-> Ver T : RM-696
-> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805
MKII : Init pipe 00
MKII : Flashing...
MKII : Finalizing...
cert-sw Flash done
MKII : ERROR_SECURITY! PHONE REPORT DOWNGRADE TRY!
Receiving error list...
Last Errors : bb5_rdc_cert_read failed
Downgrade disallowed (1354187757)
[Pipe 0] Finishing in error state with status 10
Flashing failed
More info in Last Error Log
Elapsed: 00:00:19
Core : v1.76 , BB5XG FlashEngine : v7.0
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
Flashing phone now...
Rules accepted for : Unknown Generation
Check files done...
-> SWversion check skipped : Dead mode selected
-> Sorry, can't flash it now - please send report to support
Also flashed with this file:
Check : Processing 670D5405_DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin
FW APE version : 40.2012.21-3.468.1
FW Region ver : 468
Waiting for NOLO...
Phone Info :
NOLO : 01/06/23
FW Region ver : 454
Read info Ok
File : 670D5405_DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin
MKII mode init Ok
Device : RM-696
HW build : 1603
Bat.level : 100
Protocol : 108
UPDAPP ver : 1.7.2
Upd/Dev PT : 3 , 3
Code Match Ok
HW match Ok
Processing File : 670D5405_DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin
-> Ver T : RM-696
MKII : Init pipe 00
MKII : Flashing...
cert-sw Flash done
Flashing failed
Elapsed: 00:00:13
please best team help me to revive my phone
yuo can give me the link for the appropriate file
Thank you!
The Following User Says Thank You to msajum For This Useful Post:
Old 12-05-2013, 07:52   #2 (permalink)
Member: 714291
Thanks Meter: 38
Please Best Team
Help me to revive my phone
Thank you!
Old 12-06-2013, 06:23   #3 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,158
I see some problems with N9 FW's in Navimanager. Let me fix it and find correct fw for your phone. 1-2 hours.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 12-08-2013, 11:44   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,158
Try that one.
Must work.
Link
Old 12-11-2013, 11:17   #5 (permalink)
Member: 714291
Thanks Meter: 38
Originally Posted by Dzirt View Post
Try that one.
Must work.
Link
Thank you very much Dzirt
The file u gave is working fine
My phone is alive and here is the log
registered to: msajum
Check : Processing 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin
FW Region ver : 454
Waiting for NOLO...
Phone Info :
NOLO : 01/06/23
FW Region ver : 454
Read info Ok
File : 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin
MKII mode init Ok
Device : RM-696
HW build : 1603
Bat.level : 100
Protocol : 108
UPDAPP ver : 1.7.2
Upd/Dev PT : 3 , 3
Code Match Ok
HW match Ok
Processing File : 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin
-> Ver T : RM-696
MKII : Init pipe 00
MKII : Flashing...
cert-sw Flash done
MKII : Sending config for [kernel]
-> Ver I : 2.6.32-20121301+0m8
MKII : Init pipe 01
MKII : Flashing...
kernel Flash done
MKII : Sending config for [rootfs]
-> Ver I : DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454
MKII : Init pipe 02
MKII : Flashing...
rootfs Flash done
MKII : Sending config for [cmt-2nd]
-> Ver T : RM-696
MKII : Init pipe 03
MKII : Flashing...
cmt-2nd Flash done
MKII : Sending config for [cmt-algo]
-> Ver T : RM-696
MKII : Init pipe 04
MKII : Flashing...
cmt-algo Flash done
MKII : Sending config for [cmt-mcusw]
-> Ver I : 9.2.2011.51
-> Ver T : RM-696
MKII : Init pipe 05
MKII : Flashing...
cmt-mcusw Flash done
MKII : Sending config for [xloader]
-> Ver I : 2.3.6+0m7
-> Ver T : RM-696
MKII : Init pipe 06
MKII : Flashing...
xloader Flash done
MKII : Sending config for [secondary]
-> Ver T : RM-696
MKII : Init pipe 07
MKII : Flashing...
secondary Flash done
Switch : OSSO UART+USB
Version : DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454
Update SW release Ok
Done!
Elapsed: 00:02:48
Old 12-11-2013, 13:38   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,158
I fixed Navi base for PR regions, so, in v1.77 you can find all PR-xxx firmwares.
Old 08-23-2014, 11:36   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,158
Originally Posted by jumper77 View Post
bro help lumia n9 how to fkashing to atf box pls,,,,,,,,,,,,,,,
smash phone by wall. After it will be okay. It work , "brooooo"
Old 08-24-2014, 05:03   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,158
plss upload working firmware..
Here is firmware
Take and use!
Page generated in 0.35103 seconds with 7 queries
