09-16-2018, 06:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | NEW HMD MTK Driver issues having trouble with connecting new hmd mtk phones with connecting to BEST SW, the driver under usb serial ports name is mtk usb port , the old phones is nokia mtk usb port how to solve ? |
09-16-2018, 07:09 | #2 (permalink) |
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | here is read info with cm2mtk Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 288 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : A01A227A3FCC87CF8752BEC25782A998 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : M215_61M_PCB01_gprs_MT6261_S00.N_0905.bin FileVersion : N_0905 Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
09-16-2018, 19:06 | #3 (permalink) | |
what is the problem with BEST ? post operation log text | |
06-17-2019, 01:58 | #5 (permalink) |
No Life Poster Join Date: Jan 2005 Location: ALGERIA Age: 53
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | same with nokia 130 TA-1017 connect ok with cm2mtk but can't connect it with best soft !! ????? all usb drivers installed from support area ! |
06-20-2019, 13:27 | #6 (permalink) | |
Junior Member Join Date: Nov 2011
Member: 1687169 Status: Offline Sonork: best4best Thanks Meter: 7 | Quote:
https://mega.nz/#!M5w3GIqa!b0A2duMlv...LfEAPWwS8VxaUA | |
