03-09-2014, 20:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 56387 Status: Offline Thanks Meter: 10 | Nokia N70 Erase APE group error! Now i try full earse flash before a full backup.... now i can get the phone full flashed, Erase APE group error! any workaround??? thanks!!!! this are the log::: Full Erase Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x007FFFFF Init Erase Mode Ok Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... Erase CMT : erase Ok Switch jaf to FBUS... FbusMode set Ok Full Flash With the latest version:5.0737 Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x007FFFFF Init Erase Mode Ok Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... Erase CMT : erase Ok Switch jaf to FBUS... FbusMode set Ok Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x007FFFFF Init Erase Mode Ok Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... CMT : erase Ok PrReq : NOR, 00 Switch jaf to FBUS... FbusMode set Ok User ACCEPTED FULL ERASE Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1D000206596B5D51E75BC4665E174961B51EE142 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLASHID : 225000EC , CMT , NOR FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Boot done! CMT : Read NPC certificate... CMT : Read CCC certificate... CMT : Read HWC certificate... CMT : Read VARIANT certificate... - > No any CRT data (MCU damaged/CERT erased), skip saving Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x007FFFFF Init Erase Mode Ok Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... Erase CMT : erase Ok Switch jaf to FBUS... FbusMode set Ok Core : v1.73 , BB5XG FlashEngine : v5.9 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm84_50737301.c0 PPM : RM84_0547341_5.0737.3.0.1_001.vpl Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1D000206596B5D51E75BC4665E174961B51EE142 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLASHID : 225000EC , CMT , NOR FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Boot done! CMT : Read NPC certificate... CMT : Read CCC certificate... CMT : Read HWC certificate... CMT : Read VARIANT certificate... - > No any CRT data (MCU damaged/CERT erased), skip saving Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1D000206596B5D51E75BC4665E174961B51EE142 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLASHID : 225000EC , CMT , NOR FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Boot done! Partitioning.... Partitioning Ok... TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm84_50737301.c0 Init Erase Mode Ok Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0052B515 CMT , NOR , Area : 0x006A0000 - 0x006BFFFF CMT , NOR , Area : 0x006DF000 - 0x006EFFFF CMT , NOR , Area : 0x00700000 - 0x007EFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Error select APE Asic! Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0000FFFF APE , NAND , Area : 0x00010000 - 0x0001FFFF APE , NAND , Area : 0x00020000 - 0x000203FF APE , NAND , Area : 0x00050000 - 0x03ECFFFF Erasing, wait..... Erase APE group error! ERR : 550200370037C7 Error... Connect phone on selected interface... Switch jaf to FBUS... Error Switch to FBUS |
03-10-2014, 00:39 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | if u have jaf or ufs , start jaf or ufs then select n70 from product list then press check f bus cable if u have same erorr checking anothere cable if u have same erorr ur phone has boot problem so checking hardware. |
03-11-2014, 00:07 | #4 (permalink) |
Member: 592636 Status: Offline Thanks Meter: 674 | many of n70 and n72 have ape boot problem so phone start white lcd or hang at logo so user thinking need flashing so flashing and show ape erorr so phone may be off and user cannot back to before flashing so best way at same time connect phone to ufs and only press check fbus so if ape has boot problem so shownig erorr so user only need checking hardware with lower risck. |
03-11-2014, 08:23 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | BEST show APE info WELL , so, nothing more need for check - in log clearly can be found : CMT , APE. I not see in log APE - that mean - APE not run in phone. |
