06-19-2014, 11:29 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1876649 Status: Offline Sonork: 100.1615837 Thanks Meter: 14 | Nokia N8 SimLock status : SimLock Damaged ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock Damaged!!!!! - > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Read info Code: Reading Phone Info.... Connected phone - Nokia N8-00 Software ver : V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI : 357398047485302 XappVer : 00000780 Ape Ver : 111.040.1511 APE Var : 111.040.1511111.040.1511.14.01111.040.1511.C06.01 APE ADSP: 256 DSP Ver : 92_12w18 APE Test: 0.162 PPM : CNT : Product SN : CEO541754 Product code : 0599398 Base Prd.code: 0597466 Long Prod.SN : 0 Hardware info======= HWID : 7600 Retu : 35 Tahvo : 00 Batery: 3702 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 357398047485302 IMEI spNet : 3A 75 93 08 74 84 35 00 IMEI svNet : 33 75 93 08 74 84 35 40 F5 Unable to read Lock table... :( CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Damaged!!!!! Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! check security Code: Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock Damaged!!!!! :( - > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
06-19-2014, 12:35 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Which backup? You think, if you read rpl from dead phone with damqged simlock and write it back - it will be fixed? If restore sl gives nothing - only buy rpl. |
