02-17-2015, 18:47 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | nokia n81 sl2 can not unlock with best dongle here is logs onnect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Unlock procedure started... Phone Imei: 356993018016127 Checking locks... Conf key : 0000000000000000 Provider key : 2140100000000000 Country : Spain Operator : vodafone ES Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL2 phone detected... Key file exists, no need to read... NCK unlock failed, will try direct RPL Phone Imei: 356993018016127 Key file exists, no need to read... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok Writing SimLock Key... Error Direct RPL Unlock Error! [SL3 phone?] Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! Unlock procedure started... Phone Imei: 356993018016127 Checking locks... Conf key : 0000000000000000 Provider key : 2140100000000000 Country : Spain Operator : vodafone ES Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL2 phone detected... Key file exists, no need to read... NCK unlock failed, will try direct RPL Phone Imei: 356993018016127 Key file exists, no need to read... Check phone mode... Phone already in Test mode, skip change... Writing SimLock Data... Ok Writing SimLock Key... Error Direct RPL Unlock Error! [SL3 phone?] http://i60.tinypic.com/2a68j89.jpg http://i61.tinypic.com/2a7dabo.jpg |
02-17-2015, 19:08 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Remove : BEST/Special/special.log Restart BEST and do all operations via ufs or jaf as interface. |
