Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066
Sonork: 100.1658197 Thanks Meter: 642 | Quote:
Originally Posted by JayDi Images tells NOTHING.
Software make TEXT logs. USE THEM. ALWAYS USE TEXT LOGS!
Rest - USELESS. | Jaydi bro here is log Quote:
Connect phone on selected interface...
Check : Processing DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin
FW APE version : 40.2012.21-3
FW CMT version : 9.2.2011.51
FW PRx release : PR_1.3
FW Region info : PACIFIC , ASIA (exclude China) , Australia , New Zeland
FW Region ver : 005
KERNEL version : 2.6.32-20121301+0m8
Check : File Is Ok !
Check : Processing DFL61_HARMATTAN_40.2012.13-7.SEAP_EMMC_SEAP.bin
eMMC version : DFL61_HARMATTAN_40.2012.13-7.SEAP
Core : v2.12 , Tablet FlashEngine : v5.6
Insert cable in to powered OFF phone! (Ignore if phone Connected)
Waiting for NOLO...
=== SW version Check ====
Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!)
Processing APE Boot...
File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin
Processing : ape-algo
APE Algorithm boot Error
Boot error #1
Try again few times. Check cable and battery
Elapsed: 00:00:31
Waiting for NOLO...
Connect in NOLO mode Ok!
Phone Info :
Type : RM-696 , HWRev : 1507
NOLO : 01/06/23
SWVer: DFL61_HARMATTAN_40.2012.21-3_PR_005
Device mode : Production mode
FW Region ver : 005
Read info Ok
Ok [Reflashing or Upgrade]
APE Algorithm boot Ok
Reopening the connection...
MKII mode init Ok
Device : RM-696
HW build : 1507
Bat.level : (empty)
SW release : (empty)
Protocol : 108
UPDAPP ver : 1.7.2
Upd/Dev PT : 3 , 3
FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw
Last errors : bb5_rdc_cert_read failed
bmeipc_open failed
Could not read battery level
Code Match Ok
HW match Ok
=========== ERROR =============
Can't read battery level!
Seems as RENO / Power fault. Check N4200(TWL) and N1130
MKII Set : Host Protocol set to 108
MKII Set : CMT Verify On
MKII Set : Modem Factory Set is On
MKII Set : eMMC preserve Off
---Processing MCU image---
Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin
MKII : Sending config for [cert-sw]
-> Ver T : RM-696
-> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805
MKII : Init pipe 00
MKII : Flashing...
MKII : Finalizing...
cert-sw Flash done
MKII : Sending config for [kernel]
-> Ver I : 2.6.32-20121301+0m8
MKII : Init pipe 01
MKII : Flashing...
kernel Flash done
MKII : Sending config for [rootfs]
-> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_005
MKII : Init pipe 02
MKII : Flashing...
rootfs Flash done
MKII : Sending config for [cmt-2nd]
-> Ver T : RM-696
MKII : Init pipe 03
MKII : Flashing...
cmt-2nd Flash done
MKII : Sending config for [cmt-algo]
-> Ver T : RM-696
MKII : Init pipe 04
MKII : Flashing...
cmt-algo Flash done
MKII : Sending config for [cmt-mcusw]
-> Ver I : 9.2.2011.51
-> Ver T : RM-696
MKII : Init pipe 05
MKII : Flashing...
cmt-mcusw Flash done
MKII : Sending config for [xloader]
-> Ver I : 2.3.6+0m7
-> Ver T : RM-696
MKII : Init pipe 06
MKII : Flashing...
xloader Flash done
MKII : Sending config for [secondary]
-> Ver T : RM-696
MKII : Init pipe 07
MKII : Flashing...
secondary Flash done
Switch : OSSO UART+USB
Version : DFL61_HARMATTAN_40.2012.21-3_PR_005
Update SW release Ok
---Processing eMMC image---
Processing File : DFL61_HARMATTAN_40.2012.13-7.SEAP_EMMC_SEAP.bin
MKII : Sending config for [mmc]
-> Ver I : DFL61_HARMATTAN_40.2012.13-7.SEAP
MKII : Init pipe 08
MKII : Flashing...
mmc Flash done
Done!
Elapsed: 00:06:53
Phone disconected!
