07-09-2015, 10:10 | #1 (permalink) |
Freak Poster Join Date: May 2014 Location: Bangladesh Age: 30
Member: 2178205 Status: Offline Sonork: 100.1662754 Thanks Meter: 22 | Nokia N9 Flash Problem ,,,,, Core : v2.08 , Tablet FlashEngine : v5.6 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454 Device mode : Production mode ========== FW APE version : 40.2012.21-3.454.6 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 454 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : User Request === SW version Check ==== Processing APE Boot... File : rm696_A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... MKII mode init Ok Device : RM-696 HW build : 1603 Bat.level : 61 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok MKII Set : Host Protocol set to 108 MKII Set : CMT Verify On MKII Set : Modem Factory Set is On MKII Set : eMMC preserve Off ---Processing MCU image--- Processing File : rm696_A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin MKII : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 00 MKII : Flashing... MKII : Finalizing... cert-sw Flash done MKII : ERROR_SECURITY! PHONE REPORT DOWNGRADE TRY! Receiving error list... Last Errors : bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed Downgrade disallowed (1354187757) [Pipe 0] Finishing in error state with status 10 Flashing failed More info in Last Error Log Elapsed: 00:00:16 Phone disconected! Connect phone on selected interface... Connect phone on selected interface... |
07-09-2015, 10:31 | #3 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Learn MeeGo info in search. NaviManager in BEST have PR versions info. | |
