12-14-2014, 15:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Barisal, Bangladesh Age: 40
Member: 1003712 Status: Offline Sonork: 100.1584552 Thanks Meter: 4,294,967,295 | Nokia N9 RM-696 flashing Done by BB5 Easy Service Tool (BEST) v1.99 Code: card found: S/N --------- registered to: -------- Connect phone on selected interface... Check : Processing DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin ========== FW APE version : 40.2012.21-3 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Check : Processing DFL61_HARMATTAN_40.2012.13-7.MEA_EMMC_MEA.bin ========== eMMC version : DFL61_HARMATTAN_40.2012.13-7.MEA ========== Check : File Is Ok ! Core : v1.99 , Tablet FlashEngine : v5.6 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3_PR_006 Device mode : Production mode ========== FW APE version : 40.2012.21-3 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... MKII mode init Ok Device : RM-696 HW build : 1603 Bat.level : 51 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mmc,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok MKII : Performing FULL WIPE... Starting Wipe... Bat.level : 51 Battery voltage is enough, starting wipe... Formatting... Can take up to 15-50 minutes, wait until process complete Do not disconnect phone, until done! Wipe error!!!! Something went wrong :( Wipe failed... Connect phone on selected interface... Prepare on format error Try again few times. Check cable and battery Elapsed: 00:03:25 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! |
The Following 5 Users Say Thank You to *Abu Musa* For This Useful Post: |
