07-29-2013, 15:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 364992 Status: Offline Thanks Meter: 28 | nokia n9 strange error Process finish OK buy phone not turn ON. Also tried with WIPE. i cant get it alive again. Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_30.2012.07-1.324.01.1_PR_324 Device mode : Production mode ========== FW APE version : 30.2012.07-1.324.01.1 FW PRx release : PR_1.2 FW Region info : BRANDED TO CARRIER FW Region ver : 324 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1603 Bat.level : 22 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_001 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... RFS : ERROR_PIPE_FINAL_REQ FAILED Receiving error list... Last errors : Timeout while waiting for the HWBREAK Could not reboot into cold bootmode [Pipe 4] Finishing in error state with status 1 Flashing failed More info in Last Error Log Elapsed: 00:06:31 Phone disconected! |
07-29-2013, 16:01 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | "Some Errors" on N9 happen only, when it start die. HWBREAK mean damaged CMT part. Power or it all. Need resolder, try reflash if no luck - change CMT+APe parts. |
