09-06-2013, 12:12 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: ctg ,bangladesh Age: 42
Member: 538272 Status: Offline Sonork: 100.1589159 Thanks Meter: 71 | nokia n9 successfully flash done by best dongle Check : Processing DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin ========== FW APE version : 40.2012.21-3 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Core : v1.65 , Tablet FlashEngine : v3.1 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Maemo Phone not found Core : v1.65 , Tablet FlashEngine : v3.1 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1604 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3_PR_006 Device mode : Production mode ========== FW APE version : 40.2012.21-3 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1604 Bat.level : 89 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS : Performing SWAP WIPE... Starting Wipe... Bat.level : 89 Battery voltage is enough, starting wipe... Formatting... Can take up to 15-50 minutes, wait until process complete Do not disconnect phone, until done! RFS : Swap format Ok RFS : No any errors RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_006 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... cmt-algo Flash done RFS : Sending config for [cmt-mcusw] -> Ver I : 9.2.2011.51 -> Ver T : RM-696 RFS : Init pipe 05 RFS : Flashing... RFS : Finalizing... cmt-mcusw Flash done RFS : Sending config for [xloader] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 06 RFS : Flashing... RFS : Finalizing... xloader Flash done RFS : Sending config for [secondary] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 07 RFS : Flashing... RFS : Finalizing... secondary Flash done Switch : OSSO UART+USB Version : DFL61_HARMATTAN_40.2012.21-3_PR_006 Update SW release Ok Done! |
