01-16-2014, 21:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: nobody is perfect and i'm 1
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | nokia n900 flashing prolem |
01-17-2014, 04:54 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MeeGo|Maemo tab Select MCU (choose filter All Files) Select eMMC (vanilla v10) Flash phone. |
01-17-2014, 09:57 | #3 (permalink) |
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | when i try flashing i get this error card found: S/N 1Dxx:xxxx registered to: xxxxxxxxx Connect phone on selected interface... Check : Processing RX-51_2009SE_3.2010.02-8.203.1_PR_F5_203_ARM.bin ========== FW APE version : 3.2010.02-8.203.1 FW CMT version : rx51_ICPR82_09w47 FW PRx release : PR_1.1.1 FW Region info : UK FW Region ver : 203 KERNEL version : 2.6.28-20094803.3+0m5 ========== Check : File Is Ok ! Core : v1.78 , Tablet FlashEngine : v4.5 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_3.2010.02-8.203.1_PR_203 Device mode : R&D mode [L:01] ========== FW APE version : 3.2010.02-8.203.1 FW PRx release : PR_1.1.1 FW Region info : UK FW Region ver : 203 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_3.2010.02-8.203.1_PR_F5_203_ARM.bin NOL Part program error! - > NOL lockdown! Try flash without NOL part checking! so i untick the nolo and this what am geting Core : v1.78 , Tablet FlashEngine : v4.5 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing APE part File : RX-51_2009SE_3.2010.02-8.203.1_PR_F5_203_ARM.bin Processing : kernel , 2.6.28-20094803.3+0m5 Kernel flash Error Kernel program error! Core : v1.78 , Tablet FlashEngine : v4.5 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_3.2010.02-8.203.1_PR_203 Device mode : R&D mode [L:01] ========== FW APE version : 3.2010.02-8.203.1 FW PRx release : PR_1.1.1 FW Region info : UK FW Region ver : 203 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing APE part File : RX-51_2009SE_3.2010.02-8.203.1_PR_F5_203_ARM.bin Processing : kernel , 2.6.28-20094803.3+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_3.2010.02-8.203.1_PR_F5_203_ARM.bin Processing : rootfs , RX-51_2009SE_3.2010.02-8.203.1_PR_203 RootFs flash Ok Processing CMT part File : RX-51_2009SE_3.2010.02-8.203.1_PR_F5_203_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_09w47 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_3.2010.02-8.203.1_PR_203 Switch CMT request Ok CMT : Program... CMT : Erasing... ====== ERROR ====== Programming result : error CMT part error!!! Phone not accept CMT request!!! - > How To fix : 1. Open phone (dissasemble) 2. REHOT/RESOLDER RAPUYAMA CPU and FLASH IC near it 3. Reflash phone again ====== ERROR ====== CMT : PROG_ERROR , Last data : error CMT : Erase not done! CMT Part program error! |
