08-28-2014, 13:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Nokia Rm-945 108 Hang? Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 80 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 449B21D392F0B960291832A815F10CE6 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0xAA) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... Connect phone on selected interface... |
08-28-2014, 13:11 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hi. You must use fully charged battery. And good cable. If it is not affected by HW - it will be flashed. Otherwise - need re-solder main SOC (6250A CPU) |
The Following User Says Thank You to Dzirt For This Useful Post: |
08-28-2014, 14:50 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I not remember cases, when flashing solder chips and repair bad solder Try few times with charged battery. It can go trough , but not sure in success. |
