11-23-2015, 11:26 | #1 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2059700 Status: Offline Thanks Meter: 18 | nokia rm-969 hang on logo Code: card found: S/N xxxxxxxxx registered to: vvvvvv Connect phone on selected interface... Core : v2.08 , MTKx FlashEngine : v7.5 Verify files ... MAUI : RM-969_ROM_eMP_30.06.11 VIVA : RM-969_VIVA_eMP_30.06.11 LANG : RM-969_LANG_PACK_ROM_MH_eMP_30.06.11_001 CUST : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 JMPT : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Core : v2.08 , MTKx FlashEngine : v7.5 Verify files ... MAUI : RM-969_ROM_eMP_30.06.11 VIVA : RM-969_VIVA_eMP_30.06.11 LANG : RM-969_LANG_PACK_ROM_MH_eMP_30.06.11_001 CUST : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 JMPT : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 111 ] Sync... Initial Boot Failed (Sync Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Core : v2.08 , MTKx FlashEngine : v7.5 Verify files ... MAUI : RM-969_ROM_eMP_30.06.11 VIVA : RM-969_VIVA_eMP_30.06.11 LANG : RM-969_LANG_PACK_ROM_MH_eMP_30.06.11_001 CUST : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 JMPT : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 111 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : D6B7A8993B5AD576267DFFF2E6E27C55 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_30.06.11 SecureDecrypt : RM-969_VIVA_eMP_30.06.11 SecureDecrypt : RM-969_LANG_PACK_ROM_MH_eMP_30.06.11_001 SecureDecrypt : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 SecureDecrypt : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 [ERROR] : [ERROR] : DA_S_FLASH_INFO_NOT_EXIST SDS info wrong, seems as damaged. RPL backup impossible OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 00 FORMAT_BIN : Ok ERASE_MAUI_INFO : ERROR WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_30.06.11 Write : RM-969_LANG_PACK_ROM_MH_eMP_30.06.11_001 [ERROR] : DA_UART_RX_BUF_FULL Error While flash area!!! Flashing failed! Connect phone on selected interface... |
