03-03-2018, 10:55 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: punjab ,india
Member: 2548878 Status: Offline Thanks Meter: 97 | nokia rm1011 after flash contact service .... Phone found! [ 226 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 322162B178F4D9B95AF2D3DF4F665A33 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_30.06.11 SecureDecrypt : RM-1011_VIVA_eMP_30.06.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_MH_eMP_30.06.11_001 SecureDecrypt : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 SecureDecrypt : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : PEARL.20.10.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_30.06.11 Write : RM-1011_LANG_PACK_ROM_MH_eMP_30.06.11_001 Write : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 Write : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 Write : RM-1011_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_30.06.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_MH_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now |
The Following User Says Thank You to vikas mahajan For This Useful Post: |
03-03-2018, 19:02 | #4 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | then flash this file Nokia 225 Dual Sim RM-1011 v10.01.11 Arabic Urdu Flash File |
03-04-2018, 19:28 | #5 (permalink) | |
Member: 2548878 Status: Offline Thanks Meter: 97 | Quote:
Also try some others files from support but no success... Read firmware rpl then security is ok.. Any other thing for me to do pls help.. Sent from my Redmi Note 4 using Tapatalk | |
03-05-2018, 08:27 | #8 (permalink) |
Member: 2548878 Status: Offline Thanks Meter: 97 | here is rpl log sir Card found: S/N : 03CA9A6F , v0122 Registered to: vikasmahajan1711 Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 226 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 322162B178F4D9B95AF2D3DF4F665A33 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.10.01.11.p3 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA0_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 354266069597382 BBUID : 322162B178F4D9B95AF2D3DF4F665A33 PCCode: 059V5S3 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 354266069597382_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... |
03-05-2018, 09:30 | #10 (permalink) |
Member: 2548878 Status: Offline Thanks Meter: 97 | same error sir contact service all ready try this Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_ME_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_ME_APAC_ID_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_ME_APAC_ID_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 226 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 322162B178F4D9B95AF2D3DF4F665A33 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.10.01.11.p3 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_20.10.11 SecureDecrypt : RM-1011_VIVA_eMP_20.10.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_ME_eMP_20.10.11_002 SecureDecrypt : RM-1011_CUSTPACK_ROM_ME_APAC_ID_eMP_20.10.11_002 SecureDecrypt : RM-1011_JUMP_TABLE_ME_APAC_ID_eMP_20.10.11_002 OVRLP : 000069B900000001 PHPID : PEARL.10.01.11.p3 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_20.10.11 Write : RM-1011_LANG_PACK_ROM_ME_eMP_20.10.11_002 Write : RM-1011_CUSTPACK_ROM_ME_APAC_ID_eMP_20.10.11_002 Write : RM-1011_JUMP_TABLE_ME_APAC_ID_eMP_20.10.11_002 Write : RM-1011_VIVA_eMP_20.10.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_20.10.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_ME_eMP_20.10.11_002 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_ME_APAC_ID_eMP_20.10.11_002 [VERIFY] DONE : RM-1011_JUMP_TABLE_ME_APAC_ID_eMP_20.10.11_002 [VERIFY] DONE : RM-1011_VIVA_eMP_20.10.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:44 Reboot phone Ok |
