10-22-2018, 09:11 | #1 (permalink) | |
Freak Poster Join Date: Oct 2012
Member: 1823649 Status: Offline Sonork: 100.1623331 Thanks Meter: 54 | nokia ta-1010 no power after flash before stuck on nokia logo here logs- Quote:
10-22-2018, 14:09 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | TA-1010 is pure HMD, there should be no security differ between versions. But since in device were V21, can't say. Will try find such device and check it. Right now need get FW v21, and check with this one. FW version you can get from any log Code: PTFN : Nokia USB Serial Port (COM55) MODE : NOKIA USB SERIAL PORT : 55 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 76E37EBA620CD722DB55B12C7247F28C BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.21.10.11.p1 AGENT : Look for suitable BootChain in DA ... |
10-22-2018, 15:34 | #7 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | tested TA-1034 downgrade from 30.04.11 30.04.11 > 10.02.11 No power on 30.04.11 > 11.00.11 No power on 30.04.11 > 12.00.11 No power on 30.04.11 > 30.04.11 OK 12.00.11 > 10.02.11 OK 12.00.11 > 11.00.11 OK TA-1010_059Z135_30.04.11... and others uploaded on infinity support 2018-10-16 BR, alex |
The Following 3 Users Say Thank You to aleksa55 For This Useful Post: |
10-22-2018, 16:10 | #8 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
We will make something to check that better, or make something to ignore version check. | |
10-22-2018, 16:14 | #9 (permalink) |
Member: 22466 Status: Offline Thanks Meter: 282 | is possible to make flash file from full dump ? i upload 3 dump files on infinity support |
The Following User Says Thank You to aleksa55 For This Useful Post: |
11-19-2018, 17:50 | #12 (permalink) | |
Junior Member Join Date: Jul 2011
Member: 1614823 Status: Offline Thanks Meter: 0 | Quote:
TA-1010 10.02.11 - 12.00.11 - ok 12.00.11 - 10.02.11 - ok 10.02.11 - 30.04.11 - does not turn on 12.00.11 - 30.04.11 - does not turn on 30.04.11 - 10.02.11 - ok 30.04.11 - 12.00.11 - ok. How to russify the phone (there is Russian full 30.04.11)? | |
11-23-2018, 06:01 | #13 (permalink) | |
