05-01-2018, 07:46 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Nokia Ta-1010 Support what about nokia Ta-1010 support i have two handset one for blink format but same need firmware 2nd for contact services can't find firmware on support i have readed bin file from best tool is this any help for making best support firmware. thanks you |
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post: |
05-01-2018, 09:27 | #3 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | read file bin Code: --- Insert USB cable now! --- Wait for phone... Phone found! [ 15 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 7CF71B73C70DEE0A09403F5962FB8051 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : N103.12.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info IMEI : 35********** BBUID : 7CF71B73C70DEE0A09403F5962FB8051 PCCode: 059Z1B8 SimLock Info : STATE : OPENED ( NOT LOCKED ) Dump Saved to : 357***********_MTKx.bin RPL Saved to : 357************_MTKx.mtsec Read Done! |
05-01-2018, 16:56 | #4 (permalink) |
Product Supporter Join Date: Jun 2010 Location: Infinity Team support
Member: 1330296 Status: Offline Thanks Meter: 1,137 | Latest MTK Nokia from HMD require ROOT_CERT and certified download. Right now we not have enough special data to make it. |
The Following User Says Thank You to Infinity-BEST For This Useful Post: |
05-04-2018, 00:33 | #5 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | TA-1030 ( Retro ) do not require anything, but DA1_Retro_TA1030_TA1008_v5.1719.00.01_eMP.bin for flashing guess, it is one of "latest HMD MTK-based phones" ? |
The Following User Says Thank You to the_laser For This Useful Post: |
05-04-2018, 05:05 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Unfortunately I didn't have this DA to check it. Just according SecStatus from device. It sec status is 0x17, like in some alcatel devices with enabled sla/cert. Have FW from factory, probably, and it plain, without any rc4. If DA RC4 encrypted - then all goes via bootloader, if not - must present sla. |
05-04-2018, 05:19 | #7 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Yangon Age: 29
Member: 2006794 Status: Offline Sonork: 100.1664636 Thanks Meter: 164 | Bro Try to flash with OST Tool Crack https://mega.nz/#!HRdg1aiR!sjp4c_ogg...61LALIMfKFnEGQ Zero_Control |
05-04-2018, 06:09 | #8 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
05-04-2018, 15:21 | #9 (permalink) | |
Member: 9519 Status: Offline Thanks Meter: 2,150 | Quote:
05-05-2018, 06:43 | #10 (permalink) | |
So, need just find this, and other TA-xxx line DA Firmwares and encryption not a problem at all. Users read enough dumps to make FW's. | |
