06-30-2019, 08:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | nokia ta-1017 after flash dead and backup file not write error help Code: Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM41) MODE : NOKIA USB SERIAL PORT : 41 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 05D7299C4C2CA437EB0C48AEEB94B7A1 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_MD_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_MD_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_MD_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_MD_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_MD_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_MD_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_11.02.11 Write : TA-1017_LANG_PACK_ROM_MD_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_MD_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_MD_eMP_11.02.11_001 Write : TA-1017_VIVA_eMP_11.02.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! |
06-30-2019, 09:32 | #2 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | solution here http://forum.gsmhosting.com/vbb/f641...000-a-2632860/ |
The Following User Says Thank You to kothamamun For This Useful Post: |
