10-29-2020, 12:41 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Drivers are at support area https://forum.gsmhosting.com/vbb/f64...-more-2762872/ Code: ... New drivers for 105/110/220 can be found at support area ... | |
12-01-2020, 05:47 | #13 (permalink) |
Freak Poster Join Date: Jul 2004 Location: casablanca Age: 57
Member: 75223 Status: Offline Thanks Meter: 62 | read the manual from support In case of connection problems with Nokia 105(2019), Nokia 110(2019), Nokia 220 4G(2019) required to install drivers manually. 0. Install SPRD_NPI_SVC_NK2019 driver 1. Power off phone. Open DeviceManager on PC. 2. Connect phone. New line in device manager will appear ( unknown device in most case ). - > Right click -> properties - > driver - > update -> select manual driver installation -> select from installed drivers list - > Ports (COM LPT ) category -> DriverCoding Corporation -> SPRD US2 Diag ( ver 2.0.0.131 (2015) ) Since device resets fast, maybe require 2-3 more try for catch it in list. Require remove battery and cable for reset. If driver not install after all steps - repeat operation from P1-P2 and after select US2Diag, before press "Next" - remove battery, cable. Insert them back. When device connect again - press "Next" AND we hope that team put the flashing soon |
The Following 4 Users Say Thank You to lasfar For This Useful Post: |
