08-19-2019, 13:53 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Quote: cant c any log which drivers work ? | |
The Following User Says Thank You to Y2ksalman For This Useful Post: |
08-22-2019, 08:58 | #3 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 596071 Status: Offline Thanks Meter: 160 | Quote: 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : Spreadtrum Boot Block version 1.2 ERROR : Protocol HandShake failed! Error : Fail to init protocol! Unsupported device! Reconnect Power/Cable! | |
The Following User Says Thank You to memobiles For This Useful Post: |
08-22-2019, 12:31 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | it looks very similar to wrong connection. be sure that battery is enough charged and that phone has no hw fault and then make this: 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
08-26-2019, 09:18 | #8 (permalink) |
Freak Poster Join Date: Nov 2016 Location: karachi
Member: 2650777 Status: Offline Sonork: 100.650600 Thanks Meter: 161 | Card found : 67523F15 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Read Flash Dump [ v1.18 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : Spreadtrum Boot Block version 1.2 ERROR : Protocol HandShake failed! Error : Fail to init protocol! Unsupported device! Reconnect Power/Cable! |
08-27-2019, 10:42 | #9 (permalink) |
Freak Poster Join Date: Mar 2013 Location: In your Mind Age: 35
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 153 | Operation : Reset Settings(Formet FS) [ v1.18 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : Spreadtrum Boot Block version 1.2 ERROR : Protocol HandShake failed! Error : Fail to init protocol! Unsupported device! Reconnect Power/Cable! @infinity-team, how can we remove this phone screen lock????? |
08-31-2019, 12:04 | #11 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 950964 Status: Offline Thanks Meter: 161 | Operation : Reset Settings(Formet FS) [ v1.18 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : Spreadtrum Boot Block version 1.2 ERROR : Protocol HandShake failed! Error : Fail to init protocol! Unsupported device! same here |
09-04-2019, 13:52 | #13 (permalink) |
No Life Poster Join Date: Feb 2007 Location: pakistan
Member: 456932 Status: Offline Thanks Meter: 53 | same here code not removed infinity team do something here is log Operation : Reset Settings(Formet FS) [ v1.18 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : Spreadtrum Boot Block version 1.2 ERROR : Protocol HandShake failed! Error : Fail to init protocol! |
