08-09-2018, 06:59 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | nokia unlockin delay. i put this phone .when in possition 9 in the que now in 19 ? Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-02 Software ver : V 12.04 20-05-13 RM-694 (c) Nokia IMEI 1 : 354142055283081 IMEI 2 : 354142055283099 XappVer : 000008F2 PPM : V 12.04 20-05-13 RM-694 (c) Nokia MH CNT : Content: mh_059D187 V 12.04 20-05-13 RM-694 (c) Nokia Product SN : 58B3378BI Product code : 059N3X8 Base Prd.code: 059C943 Module code : 0204922 Long Prod.SN : 0 Hardware info======= HWID : 2002 Battery: 3899 mV CMT BT: 19e2-47026 LCDVer: TPO Lock info =========== IMEI : 354142055283081 IMEI spNet : 3A 45 41 02 55 82 03 08 IMEI svNet : 33 45 41 02 55 82 03 18 F4 Sl Conf : 655-10-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 624DDAC782E81EAC Country : South Africa Operator : MTN Lock info: Block 1 L1:Close; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Unlock procedure started... job EXECUTING position 26 Unlock Error! check now. |
08-10-2018, 10:26 | #3 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-02 Software ver : V 12.04 20-05-13 RM-694 (c) Nokia IMEI 1 : 354142055283081 IMEI 2 : 354142055283099 XappVer : 000008F2 PPM : V 12.04 20-05-13 RM-694 (c) Nokia MH CNT : Content: mh_059D187 V 12.04 20-05-13 RM-694 (c) Nokia Product SN : 58B3378BI Product code : 059N3X8 Base Prd.code: 059C943 Module code : 0204922 Long Prod.SN : 0 Hardware info======= HWID : 2002 Battery: 3914 mV CMT BT: 19e2-47026 LCDVer: TPO Lock info =========== IMEI : 354142055283081 IMEI spNet : 3A 45 41 02 55 82 03 08 IMEI svNet : 33 45 41 02 55 82 03 18 F4 Sl Conf : 655-10-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 624DDAC782E81EAC Country : South Africa Operator : MTN Lock info: Block 1 L1:Close; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Unlock procedure started... Using F-bus count... Sending code 037630640357462 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! |
The Following User Says Thank You to ibrajinja For This Useful Post: |
