03-21-2020, 10:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: lagos nigeria
Member: 1278793 Status: Offline Thanks Meter: 68 | nokia x flashing error Registered to: melotech Connect phone on selected interface... Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6R1_IMEA_NG_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6R1_IMEA_NG_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6R1_IMEA_NG_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6R1_IMEA_NG_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : FFDBCE96 HWDetails : 0x000B , 0x0FC5 , 0x0081 , 0x0770 HWDetails : eMMC : VEN 15 , OEM : 0X100 , NAME : J5XWMB HWDetails : HW Revision V1 Processing : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing [ERROR_dFlIm] : FAILflash write failure Partition Flash Error , something went wrong Flash Error Break flashing! Phone disconected! Connect phone on selected interface... Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6R1_IMEA_NG_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : FFDBCE96 HWDetails : 0x000B , 0x0FC5 , 0x0081 , 0x0770 HWDetails : eMMC : VEN 15 , OEM : 0X100 , NAME : J5XWMB HWDetails : HW Revision V1 Processing : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_preload.img Init Ok, send data ... Data sent, start flashing [ERROR_dFlIm] : FAILflash write failure Partition Flash Error , something went wrong Flash Error Break flashing! Phone disconected! Connect phone on selected interface... |
