03-15-2015, 12:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1714224 Status: Offline Thanks Meter: 18 | nokia x rm 980 after flash dead Code: Connect phone on selected interface... Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_V2_1.2.4.21_059W120_IMEA_PK_V2_variant.img Ok, Set : RM980_V2_1.2.4.21_boot.img Ok, Set : RM980_V2_1.2.4.21_cache.img Ok, Set : RM980_V2_1.2.4.21_emmc_appsboot.mbn Ok, Set : RM980_V2_1.2.4.21_emmc_appsboothd.mbn Ok, Set : RM980_V2_1.2.4.21_fat.bin Ok, Set : RM980_V2_1.2.4.21_oemsbl.mbn Ok, Set : RM980_V2_1.2.4.21_oemsblhd.mbn Ok, Set : RM980_V2_1.2.4.21_persist.img Ok, Set : RM980_V2_1.2.4.21_preload.img Ok, Set : RM980_V2_1.2.4.21_qcsbl.mbn Ok, Set : RM980_V2_1.2.4.21_qcsblhd_cfgdata.mbn Ok, Set : RM980_V2_1.2.4.21_recovery.img Ok, Set : RM980_V2_1.2.4.21_system.img Ok, Set : RM980_V2_1.2.4.21_udisk.bin Ok, Set : RM980_V2_1.2.4.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_V2_1.2.4.21_059W120_IMEA_PK_V2_variant.img Ok, Set : RM980_V2_1.2.4.21_boot.img Ok, Set : RM980_V2_1.2.4.21_cache.img Ok, Set : RM980_V2_1.2.4.21_emmc_appsboot.mbn Ok, Set : RM980_V2_1.2.4.21_emmc_appsboothd.mbn Ok, Set : RM980_V2_1.2.4.21_fat.bin Ok, Set : RM980_V2_1.2.4.21_oemsbl.mbn Ok, Set : RM980_V2_1.2.4.21_oemsblhd.mbn Ok, Set : RM980_V2_1.2.4.21_persist.img Ok, Set : RM980_V2_1.2.4.21_preload.img Ok, Set : RM980_V2_1.2.4.21_qcsbl.mbn Ok, Set : RM980_V2_1.2.4.21_qcsblhd_cfgdata.mbn Ok, Set : RM980_V2_1.2.4.21_recovery.img Ok, Set : RM980_V2_1.2.4.21_system.img Ok, Set : RM980_V2_1.2.4.21_udisk.bin Ok, Set : RM980_V2_1.2.4.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 732D4AD Processing : RM980_V2_1.2.4.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_V2_1.2.4.21_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_V2_1.2.4.21_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.2.4.21_059W120_IMEA_PK_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:05:04 Reboot phone Ok Connect phone on selected interface... |
03-15-2015, 12:35 | #3 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Phone has HW Rev V1 and you flashed with Rev V2- Serial : 732D4AD Next time always check X/XL HW Rev version before flashing any X/XL phones in BEST Navimagaer tab and flash accordingly. Br. |
