09-03-2014, 08:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: pakistan hafizabad
Member: 700741 Status: Offline Sonork: 100.1617188 Thanks Meter: 409 | nokia X2 RM-1013 flashing error % phone dead Connect phone on selected interface... Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.0.0.11_059V782_001_01_rawprogram_unsparse _ui.xml Ok, Set : rm1013_2.0.0.11_prog_emmc_firehose_8x10.mbn Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Get Phone Initial Info Product : MSM8610 Version : 0.5 Serial : 9CED455 [FireHorse_Error] : Error while init RAW mode (NO RAW ACK)! Try flash again in DEAD mode Flash Error Break flashing! i try again flash show this error Connect phone on selected interface... Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.0.0.11_059V782_001_01_rawprogram_unsparse _ui.xml Ok, Set : rm1013_2.0.0.11_prog_emmc_firehose_8x10.mbn Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed |
09-03-2014, 09:07 | #2 (permalink) |
Member: 700741 Status: Offline Sonork: 100.1617188 Thanks Meter: 409 | My problem cleare OK here is infoo Connect phone on selected interface... Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.0.0.11_059V782_001_01_rawprogram_unsparse _ui.xml Ok, Set : rm1013_2.0.0.11_prog_emmc_firehose_8x10.mbn Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Handshake Ok Init[0] : 0x01000000 Init[1] : 0x30000000 Sending Loader ... Init Loader ... FireHose Initialized Device Init Ok Target VER : 1 Target CPU : 8x10 Target FLN : eMMC Target CNF : 1000/C000/1000 Target DBG : logbuf@0xF8021120 fh@0xF801DF88 Files in Chain : 66 Flashing now Flashing : rm1013_2.0.0.11_NON-HLOS.bin ProgInit : start 16384, num 75299 ProgDone : Finished sector address 91683 Flash Ok Flashing : rm1013_2.0.0.11_sbl1.mbn ProgInit : start 147456, num 492 ProgDone : Finished sector address 147948 Flash Ok Flashing : rm1013_2.0.0.11_sbl1.mbn ProgInit : start 148480, num 492 ProgDone : Finished sector address 148972 Flash Ok Flashing : rm1013_2.0.0.11_sdi.mbn ProgInit : start 149504, num 45 ProgDone : Finished sector address 149549 Flash Ok Flashing : rm1013_2.0.0.11_emmc_appsboot.mbn ProgInit : start 180224, num 931 ProgDone : Finished sector address 181155 Flash Ok Flashing : rm1013_2.0.0.11_emmc_appsboot.mbn ProgInit : start 181248, num 931 ProgDone : Finished sector address 182179 Flash Ok Flashing : rm1013_2.0.0.11_rpm.mbn ProgInit : start 182272, num 296 ProgDone : Finished sector address 182568 Flash Ok Flashing : rm1013_2.0.0.11_rpm.mbn ProgInit : start 183272, num 296 ProgDone : Finished sector address 183568 Flash Ok Flashing : rm1013_2.0.0.11_boot.img ProgInit : start 196608, num 14249 ProgDone : Finished sector address 210857 Flash Ok Flashing : rm1013_2.0.0.11_tz.mbn ProgInit : start 229376, num 663 ProgDone : Finished sector address 230039 Flash Ok Flashing : rm1013_2.0.0.11_tz.mbn ProgInit : start 230376, num 663 ProgDone : Finished sector address 231039 Flash Ok Flashing : rm1013_2.0.0.11_system_1.img ProgInit : start 344064, num 262160 ProgDone : Finished sector address 606224 Flash Ok Flashing : rm1013_2.0.0.11_system_2.img ProgInit : start 606600, num 16 ProgDone : Finished sector address 606616 Flash Ok Flashing : rm1013_2.0.0.11_system_3.img ProgInit : start 610352, num 257992 ProgDone : Finished sector address 868344 Flash Ok Flashing : rm1013_2.0.0.11_system_4.img ProgInit : start 868352, num 16 ProgDone : Finished sector address 868368 Flash Ok Flashing : rm1013_2.0.0.11_system_5.img ProgInit : start 872104, num 248544 ProgDone : Finished sector address 1120648 Flash Ok Flashing : rm1013_2.0.0.11_system_6.img ProgInit : start 1130496, num 16 ProgDone : Finished sector address 1130512 Flash Ok Flashing : rm1013_2.0.0.11_system_7.img ProgInit : start 1130888, num 16 ProgDone : Finished sector address 1130904 Flash Ok Flashing : rm1013_2.0.0.11_system_8.img ProgInit : start 1392640, num 16 ProgDone : Finished sector address 1392656 Flash Ok Flashing : rm1013_2.0.0.11_system_9.img ProgInit : start 1654784, num 16 ProgDone : Finished sector address 1654800 Flash Ok Flashing : rm1013_2.0.0.11_system_10.img ProgInit : start 1655176, num 16 ProgDone : Finished sector address 1655192 Flash Ok Flashing : rm1013_2.0.0.11_cache_1.img ProgInit : start 1777664, num 11376 ProgDone : Finished sector address 1789040 Flash Ok Flashing : rm1013_2.0.0.11_recovery.img ProgInit : start 1974272, num 15229 ProgDone : Finished sector address 1989501 Flash Ok Flashing : rm1013_2.0.0.11_misc_erase.img ProgInit : start 1998848, num 1 ProgDone : Finished sector address 1998849 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_1.img ProgInit : start 2015232, num 261616 ProgDone : Finished sector address 2276848 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_2.img ProgInit : start 2277376, num 16 ProgDone : Finished sector address 2277392 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_3.img ProgInit : start 2277640, num 16 ProgDone : Finished sector address 2277656 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_4.img ProgInit : start 2280856, num 250992 ProgDone : Finished sector address 2531848 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_5.img ProgInit : start 2539520, num 16 ProgDone : Finished sector address 2539536 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_6.img ProgInit : start 2542736, num 64544 ProgDone : Finished sector address 2607280 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_7.img ProgInit : start 2801664, num 16 ProgDone : Finished sector address 2801680 Flash Ok Flashing : rm1013_2.0.0.11_059V782_001_01.custom_8.img ProgInit : start 2801928, num 16 ProgDone : Finished sector address 2801944 Flash Ok Flashing : rm1013_2.0.0.11_userdata_1.img ProgInit : start 2834432, num 80248 ProgDone : Finished sector address 2914680 Flash Ok Flashing : rm1013_2.0.0.11_userdata_2.img ProgInit : start 3096576, num 16 ProgDone : Finished sector address 3096592 Flash Ok Flashing : rm1013_2.0.0.11_userdata_3.img ProgInit : start 3097800, num 16 ProgDone : Finished sector address 3097816 Flash Ok Flashing : rm1013_2.0.0.11_userdata_4.img ProgInit : start 3358720, num 16 ProgDone : Finished sector address 3358736 Flash Ok Flashing : rm1013_2.0.0.11_userdata_5.img ProgInit : start 3620864, num 16 ProgDone : Finished sector address 3620880 Flash Ok Flashing : rm1013_2.0.0.11_userdata_6.img ProgInit : start 3622088, num 16 ProgDone : Finished sector address 3622104 Flash Ok Flashing : rm1013_2.0.0.11_userdata_7.img ProgInit : start 3883008, num 16 ProgDone : Finished sector address 3883024 Flash Ok Flashing : rm1013_2.0.0.11_userdata_8.img ProgInit : start 4145152, num 16 ProgDone : Finished sector address 4145168 Flash Ok Flashing : rm1013_2.0.0.11_userdata_9.img ProgInit : start 4146376, num 16 ProgDone : Finished sector address 4146392 Flash Ok Flashing : rm1013_2.0.0.11_userdata_10.img ProgInit : start 4407296, num 16 ProgDone : Finished sector address 4407312 Flash Ok Flashing : rm1013_2.0.0.11_userdata_11.img ProgInit : start 4669440, num 16 ProgDone : Finished sector address 4669456 Flash Ok Flashing : rm1013_2.0.0.11_userdata_12.img ProgInit : start 4670664, num 16 ProgDone : Finished sector address 4670680 Flash Ok Flashing : rm1013_2.0.0.11_userdata_13.img ProgInit : start 4931584, num 16 ProgDone : Finished sector address 4931600 Flash Ok Flashing : rm1013_2.0.0.11_userdata_14.img ProgInit : start 5193728, num 16 ProgDone : Finished sector address 5193744 Flash Ok Flashing : rm1013_2.0.0.11_userdata_15.img ProgInit : start 5194952, num 16 ProgDone : Finished sector address 5194968 Flash Ok Flashing : rm1013_2.0.0.11_userdata_16.img ProgInit : start 5455872, num 16 ProgDone : Finished sector address 5455888 Flash Ok Flashing : rm1013_2.0.0.11_userdata_17.img ProgInit : start 5718016, num 16 ProgDone : Finished sector address 5718032 Flash Ok Flashing : rm1013_2.0.0.11_userdata_18.img ProgInit : start 5980160, num 16 ProgDone : Finished sector address 5980176 Flash Ok Flashing : rm1013_2.0.0.11_userdata_19.img ProgInit : start 6242304, num 16 ProgDone : Finished sector address 6242320 Flash Ok Flashing : rm1013_2.0.0.11_userdata_20.img ProgInit : start 6504448, num 16 ProgDone : Finished sector address 6504464 Flash Ok Flashing : rm1013_2.0.0.11_userdata_21.img ProgInit : start 6766592, num 16 ProgDone : Finished sector address 6766608 Flash Ok Flashing : rm1013_2.0.0.11_userdata_22.img ProgInit : start 7028736, num 16 ProgDone : Finished sector address 7028752 Flash Ok Flashing : rm1013_2.0.0.11_userdata_23.img ProgInit : start 7290880, num 16 ProgDone : Finished sector address 7290896 Flash Ok Flashing : rm1013_2.0.0.11_userdata_24.img ProgInit : start 7553024, num 16 ProgDone : Finished sector address 7553040 Flash Ok Chain finished, All files flashed! After chang driver My problem cleare thx infinty team |
The Following User Says Thank You to MALIKTARIQ For This Useful Post: |
09-16-2014, 08:58 | #4 (permalink) | |
Insane Poster Join Date: Mar 2008 Location: IRAN
Member: 723657 Status: Offline Sonork: 100.1583371 Thanks Meter: 41 | Quote:
i have same problem and cant solve how to install corect driver in windows 7 ? thanks | |
09-16-2014, 09:26 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | By hands. BY HANDS. Use WIN XP driver variant and install on your Zeus flash device or Qualcomm device. |
The Following User Says Thank You to Dzirt For This Useful Post: |
09-23-2014, 05:59 | #11 (permalink) |
Freak Poster Join Date: Nov 2004 Location: iran Age: 37
Member: 90307 Status: Offline Sonork: not hav e Thanks Meter: 24 | i install all driver but no answer add me on yahoo please [email protected] please again failed 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed |
09-23-2014, 06:49 | #12 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Remove all drivers. Install from support area : All drivers from http://server1.infinity-best.com/dow..._MTKx_Asha.rar Then http://server1.infinity-best.com/dow..._Emergency.msi Reboot PC. Flash phone. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
09-29-2014, 06:03 | #14 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Flashing done but its not getting power on ?? whats wrong Quote:
09-29-2014, 07:05 | #15 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Due logs all is Ok. Does phone startup or not at all? If it hang on Nokia - try make Wipe ( way same as for Nokia X ) and Cache reset. |
