09-30-2014, 17:27 | #17 (permalink) |
Freak Poster Join Date: Feb 2011 Location: JEMBER - indonesia Age: 36
Member: 1506640 Status: Offline Thanks Meter: 38 | help me pleace.. my nokia 1013 death boot after flash with infinity best.. im write firmware version 2.1.0.11... proses flash failed.. pleace read this log... Connect phone on selected interface... Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.0.0.11_059V782_001_01_rawprogram_unsparse _ui.xml Ok, Set : rm1013_2.0.0.11_prog_emmc_firehose_8x10.mbn Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Handshake Ok Init[0] : 0x01000000 Init[1] : 0x30000000 Sending Loader ... Init Loader ... FireHose Initialized Device Init Ok Target VER : 1 Target CPU : 8x10 Target FLN : eMMC Target CNF : 1000/C000/1000 Target DBG : logbuf@0xF8021120 fh@0xF801DF88 |
09-30-2014, 17:31 | #18 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 1. Pull out battery. Charge it. 2. Insert. Download files from NaviManager again , just to verify all is correct ( it just check existing files checksum ) 3. Select RM-1013 and flash again. |
05-29-2015, 11:30 | #27 (permalink) |
Junior Member Join Date: Oct 2014 Location: nepal,narayangadh
Member: 2272184 Status: Offline Thanks Meter: 2 | nokia 1013 flashing error Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Get Phone Initial Info Product : MSM8610 Version : 0.5 Serial : F81FD4B4 [FireHose_Error] : Error while set RAW mode (SBL Erase error)! Try flash again in DEAD mode Flash Error Break flashing! Connect phone on selected interface... |
05-29-2015, 11:45 | #28 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 2 ways : 1. If alive - flash from normal mode. 2. Use "Boot JIG" from Lumia V2 phones, which canbe found in Lumia Boot Repair manual - BEST/docs/ folder. |
