09-12-2015, 16:09 | #1 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | NOKIA XL flashing after dead Code: Core : v2.10 , NXP FlashEngine : v4.9 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6S3_IMEA_QA_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 8FE6D494 Processing : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_059V6S3_IMEA_QA_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:06:29 Reboot phone Ok code 0590W170 plz help me team |
09-12-2015, 16:33 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Yeah, I was about to post pc 0590W170 is wrong. Anyway your phone has HW Revision V2, so you needed to flash with V2 firmware. Unfortunately you flashed with 059V6S3 which is HW Revision V1, so phone gone dead. Now need jtag to revive. Next time enter pc in Nokia X/XL HWRev tab to know about HW revision before flashing. Br. |
09-12-2015, 16:40 | #6 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Quote:
