04-24-2015, 18:22 | #16 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | Core : v2.03 , NXP FlashEngine : v4.6 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.13_059V782_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.13_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed [FireHose_Error] : Phone not detected in any supported mode. Check Drivers, Cable, Battery Flash Error Break flashing! Connect phone on selected interface... Core : v2.03 , NXP FlashEngine : v4.6 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.13_059V782_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.13_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected [FireHose_Error] : Phone not detected in any supported mode. Check Drivers, Cable, Battery Flash Error Break flashing! Connect phone on selected interface... Core : v2.03 , NXP FlashEngine : v4.6 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.13_059V782_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.13_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Handshake Ok Init[0] : 0x01000000 Init[1] : 0x30000000 Sending Loader ... Init Loader ... FireHose Initialized Device Init Ok Target VER : 1 Target CPU : 8x10 Target FLN : eMMC Target CNF : 1000/C000/1000 Target DBG : logbuf@0xF8021118 fh@0xF801DF80 Files in Chain : 67 Flashing now Flashing : rm1013_2.1.0.13_user_NON-HLOS.bin ProgInit : start 16384, num 75203 ProgDone : Finished sector address 91587 Flash Ok Flashing : rm1013_2.1.0.13_user_sbl1.mbn ProgInit : start 147456, num 492 ProgDone : Finished sector address 147948 Flash Ok Flashing : rm1013_2.1.0.13_user_sbl1.mbn ProgInit : start 148480, num 492 ProgDone : Finished sector address 148972 Flash Ok Flashing : rm1013_2.1.0.13_user_sdi.mbn ProgInit : start 149504, num 45 ProgDone : Finished sector address 149549 Flash Ok Flashing : rm1013_2.1.0.13_user_emmc_appsboot.mbn ProgInit : start 180224, num 938 ProgDone : Finished sector address 181162 Flash Ok Flashing : rm1013_2.1.0.13_user_emmc_appsboot.mbn ProgInit : start 181248, num 938 ProgDone : Finished sector address 182186 Flash Ok Flashing : rm1013_2.1.0.13_user_rpm.mbn ProgInit : start 182272, num 296 ProgDone : Finished sector address 182568 Flash Ok Flashing : rm1013_2.1.0.13_user_rpm.mbn ProgInit : start 183272, num 296 ProgDone : Finished sector address 183568 Flash Ok Flashing : rm1013_2.1.0.13_user_boot.img ProgInit : start 196608, num 14549 ProgDone : Finished sector address 211157 Flash Ok Flashing : rm1013_2.1.0.13_user_tz.mbn ProgInit : start 229376, num 663 ProgDone : Finished sector address 230039 Flash Ok Flashing : rm1013_2.1.0.13_user_tz.mbn ProgInit : start 230376, num 663 ProgDone : Finished sector address 231039 Flash Ok Flashing : rm1013_2.1.0.13_user_system_1.img ProgInit : start 344064, num 262160 ProgDone : Finished sector address 606224 Flash Ok Flashing : rm1013_2.1.0.13_user_system_2.img ProgInit : start 606600, num 16 ProgDone : Finished sector address 606616 Flash Ok Flashing : rm1013_2.1.0.13_user_system_3.img ProgInit : start 610352, num 257992 ProgDone : Finished sector address 868344 Flash Ok Flashing : rm1013_2.1.0.13_user_system_4.img ProgInit : start 868352, num 16 ProgDone : Finished sector address 868368 Flash Ok Flashing : rm1013_2.1.0.13_user_system_5.img ProgInit : start 872104, num 258384 ProgDone : Finished sector address 1130488 Flash Ok Flashing : rm1013_2.1.0.13_user_system_6.img ProgInit : start 1130496, num 16 ProgDone : Finished sector address 1130512 Flash Ok Flashing : rm1013_2.1.0.13_user_system_7.img ProgInit : start 1130888, num 16 ProgDone : Finished sector address 1130904 Flash Ok Flashing : rm1013_2.1.0.13_user_system_8.img ProgInit : start 1134640, num 95696 ProgDone : Finished sector address 1230336 Flash Ok Flashing : rm1013_2.1.0.13_user_system_9.img ProgInit : start 1392640, num 16 ProgDone : Finished sector address 1392656 Flash Ok Flashing : rm1013_2.1.0.13_user_system_10.img ProgInit : start 1654784, num 16 ProgDone : Finished sector address 1654800 Flash Ok Flashing : rm1013_2.1.0.13_user_system_11.img ProgInit : start 1655176, num 16 ProgDone : Finished sector address 1655192 Flash Ok Flashing : rm1013_2.1.0.13_user_cache_1.img ProgInit : start 1777664, num 11376 ProgDone : Finished sector address 1789040 Flash Ok Flashing : rm1013_2.1.0.13_user_recovery.img ProgInit : start 1974272, num 15529 ProgDone : Finished sector address 1989801 Flash Ok Flashing : rm1013_2.1.0.13_user_misc_erase.img ProgInit : start 1998848, num 1 ProgDone : Finished sector address 1998849 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_1.img ProgInit : start 2015232, num 262136 ProgDone : Finished sector address 2277368 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_2.img ProgInit : start 2277376, num 16 ProgDone : Finished sector address 2277392 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_3.img ProgInit : start 2277640, num 16 ProgDone : Finished sector address 2277656 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_4.img ProgInit : start 2280856, num 258656 ProgDone : Finished sector address 2539512 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_5.img ProgInit : start 2539520, num 16 ProgDone : Finished sector address 2539536 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_6.img ProgInit : start 2542736, num 252928 ProgDone : Finished sector address 2795664 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_7.img ProgInit : start 2801664, num 16 ProgDone : Finished sector address 2801680 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_8.img ProgInit : start 2801928, num 16 ProgDone : Finished sector address 2801944 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_1.img ProgInit : start 2834432, num 80272 ProgDone : Finished sector address 2914704 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_2.img ProgInit : start 3096576, num 16 ProgDone : Finished sector address 3096592 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_3.img ProgInit : start 3097800, num 16 ProgDone : Finished sector address 3097816 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_4.img ProgInit : start 3358720, num 16 ProgDone : Finished sector address 3358736 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_5.img ProgInit : start 3620864, num 16 ProgDone : Finished sector address 3620880 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_6.img ProgInit : start 3622088, num 16 ProgDone : Finished sector address 3622104 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_7.img ProgInit : start 3883008, num 16 ProgDone : Finished sector address 3883024 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_8.img ProgInit : start 4145152, num 16 ProgDone : Finished sector address 4145168 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_9.img ProgInit : start 4146376, num 16 ProgDone : Finished sector address 4146392 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_10.img ProgInit : start 4407296, num 16 ProgDone : Finished sector address 4407312 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_11.img ProgInit : start 4669440, num 16 ProgDone : Finished sector address 4669456 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_12.img ProgInit : start 4670664, num 16 ProgDone : Finished sector address 4670680 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_13.img ProgInit : start 4931584, num 16 ProgDone : Finished sector address 4931600 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_14.img ProgInit : start 5193728, num 16 ProgDone : Finished sector address 5193744 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_15.img ProgInit : start 5194952, num 16 ProgDone : Finished sector address 5194968 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_16.img ProgInit : start 5455872, num 16 ProgDone : Finished sector address 5455888 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_17.img ProgInit : start 5718016, num 16 ProgDone : Finished sector address 5718032 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_18.img ProgInit : start 5980160, num 16 ProgDone : Finished sector address 5980176 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_19.img ProgInit : start 6242304, num 16 ProgDone : Finished sector address 6242320 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_20.img ProgInit : start 6504448, num 16 ProgDone : Finished sector address 6504464 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_21.img ProgInit : start 6766592, num 16 ProgDone : Finished sector address 6766608 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_22.img ProgInit : start 7028736, num 16 ProgDone : Finished sector address 7028752 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_23.img ProgInit : start 7290880, num 16 ProgDone : Finished sector address 7290896 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_24.img ProgInit : start 7553024, num 16 ProgDone : Finished sector address 7553040 Flash Ok Chain finished, All files flashed! Rebooting phone now Flashing done! Total flash time : 00:01:17 Connect phone on selected interface... Phone found! Nokia X Platform Phone detected Read info... Ok |
04-24-2015, 18:34 | #17 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | phone must be detetect as Nokia Emergency Connectivity in Universel Serial Bus Devices not com port here driver Salam |
04-26-2015, 08:24 | #19 (permalink) | ||
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Quote:
universal serial port.........usb mass storage device....usb composite device not detect as emergency nokia connectivity | ||
04-26-2015, 23:18 | #20 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | What system you use Xp or Win7?? delete drivers -> in command dos line type : set devmgr_show_nonpresent_devices=1 and type : devmgmt.msc tick on show hidden devices and remove recently installed driver , reboot system hold down button and plug usb when window appear for new decteted driver give path for driver that i have attached here Salam |
04-28-2015, 07:27 | #21 (permalink) | |
i think it's qualcomm cdma phone and it's hw version is hw v1.... in support area only v2 available... | |
05-13-2015, 09:54 | #24 (permalink) | |
i hope it will add in nest update..... thanks | |
