02-10-2016, 17:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside MTK Age: 38
Member: 248182 Status: Offline Thanks Meter: 786 | Nokia XL RM-1030 detect as USB Input Device I had received Nokia XL RM-1030 on Logo Stuck Problem. As per the product code phone hardware revision is 1. When i would like to flash it detect as USB Input device due to which can not connect with software. I have already install all driver which is extracted from folder "Nokia_WP8x_NXP_MTKx_Asha" Kindly see below the flashing log and attached screen short and help me out on this case. Code: Card found: S/N : 342B915A , v0129 Registered to: bluffmaster Connect phone on selected interface... Core : v2.19 , NXP FlashEngine : v5.1 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6P1_APAC_TH_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.19 , NXP FlashEngine : v5.1 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6P1_APAC_TH_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again |
