08-15-2014, 14:41 | #1 (permalink) |
Banned Join Date: Dec 2008
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | nokia xl rm 1030 success fully flashed.... registered to: khurramiqbal Connect phone on selected interface... Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.1.2.20_059W170_IMEA_PK_V2_variant.img Ok, Set : RM1030_V2_1.1.2.20_boot.img Ok, Set : RM1030_V2_1.1.2.20_cache.img Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.1.2.20_fat.bin Ok, Set : RM1030_V2_1.1.2.20_oemsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_oemsblhd.mbn Ok, Set : RM1030_V2_1.1.2.20_persist.img Ok, Set : RM1030_V2_1.1.2.20_preload.img Ok, Set : RM1030_V2_1.1.2.20_qcsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.1.2.20_recovery.img Ok, Set : RM1030_V2_1.1.2.20_system.img Ok, Set : RM1030_V2_1.1.2.20_udisk.bin Ok, Set : RM1030_V2_1.1.2.20_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Processing : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Partition Init Not Done Flash Error Break flashing! Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.1.2.20_059W170_IMEA_PK_V2_variant.img Ok, Set : RM1030_V2_1.1.2.20_boot.img Ok, Set : RM1030_V2_1.1.2.20_cache.img Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.1.2.20_fat.bin Ok, Set : RM1030_V2_1.1.2.20_oemsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_oemsblhd.mbn Ok, Set : RM1030_V2_1.1.2.20_persist.img Ok, Set : RM1030_V2_1.1.2.20_preload.img Ok, Set : RM1030_V2_1.1.2.20_qcsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.1.2.20_recovery.img Ok, Set : RM1030_V2_1.1.2.20_system.img Ok, Set : RM1030_V2_1.1.2.20_udisk.bin Ok, Set : RM1030_V2_1.1.2.20_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Processing : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Partition Init Not Done Flash Error Break flashing! Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.1.2.20_059W170_IMEA_PK_V2_variant.img Ok, Set : RM1030_V2_1.1.2.20_boot.img Ok, Set : RM1030_V2_1.1.2.20_cache.img Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.1.2.20_fat.bin Ok, Set : RM1030_V2_1.1.2.20_oemsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_oemsblhd.mbn Ok, Set : RM1030_V2_1.1.2.20_persist.img Ok, Set : RM1030_V2_1.1.2.20_preload.img Ok, Set : RM1030_V2_1.1.2.20_qcsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.1.2.20_recovery.img Ok, Set : RM1030_V2_1.1.2.20_system.img Ok, Set : RM1030_V2_1.1.2.20_udisk.bin Ok, Set : RM1030_V2_1.1.2.20_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 70D47F Processing : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.1.2.20_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.1.2.20_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_059W170_IMEA_PK_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:05:10 Reboot phone Ok Connect phone on selected interface... |
The Following 3 Users Say Thank You to khurram450 For This Useful Post: |
