09-06-2019, 13:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Problem flash PPM the same software version but get warning warning ------------------- Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia IMEI : 355970045999757 XappVer : 000008F2 Ape Ver : 071.005 APE Var : 071.005071.005.01.01071.005.C00.01 APE ADSP: 256 DSP Ver : ICPR82_11w16 APE Test: 10wk48v0.001_APEONLY PPM : CNT : Product SN : 18A9ECEAA Product code : 059B2J0 Base Prd.code: 0592655 Module code : 0204492 Long Prod.SN : 0 Hardware info======= HWID : 6502 Retu : 35 Tahvo : 00 Battery: 3995 mV APE HW: 256 Lock info =========== IMEI : 355970045999757 IMEI spNet : 3A 55 79 00 54 99 79 05 IMEI svNet : 33 55 79 00 54 99 79 15 F5 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! --------------- -------------- I Need Change language.. I try flash PPM with same software version but get this message...... - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! --------------------- --------------------- Selected FlashSettings : PPM only FlashFile verify disabled Files Set for Flashing : PPM : rm645_071.005_07.01_Balkans_prd.rofs2.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0970000E46D60344C694292EBAE5C78B6BC62E78 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355970045999757 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355970045999757_2n d.rpl === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Phone disconected! Connect phone on selected interface... Elapsed: 00:00:08 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
