10-13-2018, 14:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mongarrasco
Member: 107027 Status: Offline Thanks Meter: 269 | ta-1032 flash error i received a nokia ta-1032 stuck on boot logo from a customer i've downloaded this firmware and flashed with best2 now phone doesn't boot anymore and if i try to flash this is the result: Waiting for device connection ... PTFN : MediaTek USB Port (COM117) MODE : BOOTROM PORT : 117 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! any advice to recover the phone? br ss |
10-13-2018, 16:15 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | eMMC seems as dead, or some other HW fault. Right now, standalone solution - desolder emmc, write fw inside it, solder back. If eMMC alive - resolding + reflash should help to recover device. |
10-15-2018, 09:57 | #3 (permalink) |
Member: 107027 Status: Offline Thanks Meter: 269 | thx JayDi, phone before flash was in this conditions: Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM111) MODE : PRELOADER PORT PORT : 111 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A393652100762B3DCF759 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A393652100762B3DC8459 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4E82331F8000AF656E6623A9279EDDAC STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub : Patch Level : NMF26O Display ID : 00WW_2_15O Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2018-04-05 Build Time : 1523535233 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Board Platform : mt6737m Product Info : NE1 --- SecuritySub : IMEI[0] : 35339209xxxxxxx IMEI[1] : 35339209xxxxxxx NVRAM check : Passed! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
10-18-2018, 03:56 | #6 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Before make release I had made test with 10 rounds for flash Nokia 3 ( 2pc ) for stress-flashing to make sure about SW work as should. Right now exactly NK3 recover make some problems, but we are working on direct USB method. No other SW can help you right now to recover it. If you not sure in device condition - untick bootloader update option. This is accept only for Nokia 3 line. | |
08-29-2019, 21:40 | #7 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 57 | TA-1032 MT6735 firmware needed for SP tool or ??? My phone was working before flashing I try to flesh with NE1-215H-0-00WW-B02_nokia3. During flashing came an error and now phone doesn't want to flash any more. With unticked Force BL update and Pre-Erase Phone only vibrate after connect to USB. Here is the log: Load : D:\nokia\TA-1032\NE1-215H-0-00WW-B02_nokia3\NE1-215H-0-00WW-B02.nb0 Load Ok! Operation : Write FW [ v1.18 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! I think that I need firmware for SP Tool for MT6735. Can't find... BR ERSA |
09-06-2019, 09:24 | #8 (permalink) | |
Member: 75290 Status: Offline Thanks Meter: 57 | no one can help??? Quote:
BR ERSA Seb | |
