04-21-2016, 15:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | Nokia220 rm-971 fresh phone but no service help pls any idea or solution to fix it thanks in advance |
04-22-2016, 12:03 | #3 (permalink) |
Member: 153893 Status: Offline Thanks Meter: 266 | here is the logs for it sir Verify files ... MAUI : RM-971_ROM_eMP_30.06.11 VIVA : RM-971_VIVA_eMP_30.06.11 LANG : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 CUST : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 JMPT : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 32 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : DE290390533B99C1A0D109BEDD5A2E87 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.20.14.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-971_ROM_eMP_30.06.11 SecureDecrypt : RM-971_VIVA_eMP_30.06.11 SecureDecrypt : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 SecureDecrypt : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 SecureDecrypt : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : Rivendell.20.14.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-971_ROM_eMP_30.06.11 Write : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 Write : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 Write : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 Write : RM-971_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-971_ROM_eMP_30.06.11 [VERIFY] DONE : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 [VERIFY] DONE : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 [VERIFY] DONE : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 [VERIFY] DONE : RM-971_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Will Upload FAT Image now Write : RM-971_FATIMAGE_UA_30.06.11 FAT Image Flash done! FAT Verify Ok Rebooting phone now Flashing done! Total flash time : 00:04:01 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds |
07-11-2016, 21:50 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: CAIRO Age: 37
Member: 237684 Status: Offline Thanks Meter: 66 | Card found: S/N : 0F654669 , v0130 Registered to: washwshny_13 Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 23 ] Sync... Initial Boot Failed (Sync Error) Connect phone on selected interface... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 967566CCB5DF37115D51B49806F13939 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.30.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA0_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 351828072348369 BBUID : 967566CCB5DF37115D51B49806F13939 PCCode: 059V4Q6 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 351828072348369_MTKx.mtsec Read Done! Connect phone on selected interface... |
