03-21-2014, 10:14 | #1 (permalink) |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Online Sonork: 100.1654602 Thanks Meter: 1,578 | not format locked 4gb memory card registered to: vishnudatt Connect phone on selected interface... Core : v1.84 , BB5XG FlashEngine : v9.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm702__06.52.mcusw PPM : rm702__06.52.ppm_mh1 CNT : rm702__06.52_002.image_mh1_ctv_in_9k8b9 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358266042850060 IMEI 2 : 358266042850078 PCcode : 059K4Z2 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : E:\best\1.80\BEST\Backup\Cert\358266042850060_XG21 3_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm702__06.52.mcusw Image : rm702__06.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:36 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xC20B ===Flashing [PPM]=== File : rm702__06.52.ppm_mh1 Image : package_mh1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:10 Write , Start : 0x41DC0000 , Len : 0x004D1294 Flashing , wait ... Region flash done, time : 00:00:06 CRC check passed , 0x94F8 ===Flashing [CNT]=== File : rm702__06.52_002.image_mh1_ctv_in_9k8b9 Image : package_mh1_ctv_in.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:00:58 Write , Start : 0x424C0000 , Len : 0x00C20000 Flashing , wait ... Region flash done, time : 00:00:15 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x138F Flashing done! Total flash time : 00:03:09 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 06.52 29-07-11 RM-702 (c) Nokia IMEI: 358266042850060 PPM version : V 06.52 29-07-11 RM-702 (c) Nokia MH1 Product code: 059K4Z2 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Phone disconected! Connect phone on selected interface... Core : v1.84 , BB5XG FlashEngine : v9.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm702__06.52.mcusw PPM : rm702__06.52.ppm_mh1 CNT : rm702__06.52_002.image_mh1_ctv_in_9k8b9 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358266042850060 IMEI 2 : 358266042850078 PCcode : 059K4Z2 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : E:\best\1.80\BEST\Backup\Cert\358266042850060_2nd_ XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm702__06.52.mcusw Image : rm702__06.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:36 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xC20B ===Flashing [PPM]=== File : rm702__06.52.ppm_mh1 Image : package_mh1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:10 Write , Start : 0x41DC0000 , Len : 0x004D1294 Flashing , wait ... Region flash done, time : 00:00:06 CRC check passed , 0x94F8 ===Flashing [CNT]=== File : rm702__06.52_002.image_mh1_ctv_in_9k8b9 Image : package_mh1_ctv_in.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x424C0000 , Len : 0x00C20000 Flashing , wait ... Region flash done, time : 00:00:15 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x138F Flashing done! Total flash time : 00:03:14 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 06.52 29-07-11 RM-702 (c) Nokia IMEI: 358266042850060 PPM version : V 06.52 29-07-11 RM-702 (c) Nokia MH1 Product code: 059K4Z2 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:55 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done Operating mode is OK, no need change... Format ... Format Failed All done |
03-21-2014, 10:44 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Does card insert in phone? Power it on , remove card. Insert back. Make sure - phone ask for password when you try open memory card in phone manager (gallery). After do format. |
03-21-2014, 10:44 | #5 (permalink) |
03-22-2014, 06:49 | #7 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | No. He said just check mmc asks for pswd when open gallery ?... After This.. Insert MMC IN FONE To FORMAT 1. Connect fone to usb 2. Detect fone [Read info] 3. Go to Misc tab 4. Push Format Mcsd Card Result will like This: Quote:
The Following 2 Users Say Thank You to .::EXTREME::. For This Useful Post: |
03-24-2014, 07:35 | #8 (permalink) |
Freak Poster Join Date: Mar 2010 Location: pindi gheb
Member: 1270601 Status: Offline Sonork: abc Thanks Meter: 18 | 100% woking update 100% tested update open best softwear music teb format mcSD card handset like 5130,2700.2690 do job all don. unlock you,r card password or format failed messege momery card is corrupted 100%. |
03-24-2014, 08:45 | #9 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 950964 Status: Offline Thanks Meter: 161 | card found: S/N registered to: irfan sabir Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia IMEI : 354330045846881 XappVer : 00000730 Ape Ver : 071.005 APE Var : 071.005071.005.10.01071.005.C00.01 APE ADSP: 256 DSP Ver : ICPR82_11w16 APE Test: 10wk48v0.001_APEONLY PPM : CNT : Product SN : CZF266447 Product code : 0593784 Base Prd.code: 0591907 Module code : 0204492 Long Prod.SN : 0 Hardware info======= HWID : 6000 Retu : 35 Tahvo : 00 Batery: 4029 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 354330045846881 IMEI spNet : 3A 45 33 00 54 48 86 08 IMEI svNet : 33 45 33 00 54 48 86 18 F5 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Check phone mode... Phone in Normal mode Seting Local mode... wait... Local mode set Format ... Format Failed All done Reading Phone Info.... Connected phone - Nokia 3110c Software ver : V 07.30 07-05-09 RM-237 (c) Nokia. IMEI : 351939034735450 XappVer : 00000730 DSP Ver : ICPR61_08w10 PPM : V 07.30 07-05-09 RM-237 (c) Nokia. C CNT : Content: c_tr V 07.30 07-05-09 RM-237 (c) Nokia. Product SN : MYK106744 Product code : 0544325 Base Prd.code: 0542523 Module code : 0203291 Hardware info======= HWID : 5008 Retu : 32 Tahvo : 53 Batery: 3893 mV CMT BT: 06cc-P9.1 Lock info =========== IMEI : 351939034735450 IMEI spNet : 3A 15 39 09 43 37 45 05 IMEI svNet : 33 15 39 09 43 37 45 25 F7 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL phone detected User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Operating mode is OK, no need change... Format ... Format Failed All done Initializing Tests... IMEI : 351939034735450 , Phone : RM-237 Nokia 3110c Get keys... PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_RADIO_TEST PASSED | ST_BACKLIGHT_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_IRDA_LED_STRESS_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_SLEEPCLK_FREQ_TEST PASSED | ST_BTEMP_TEST PASSED | ST_BT_SLEEP_CLK_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST PASSED | ST_CDSP_TX_IQ_TEST PASSED | ST_CDSP_TXC_DATA_TEST NOT RUN | ST_CDSP_RX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST SelfTests end Done! Elapsed: 00:00:30 Phone disconected! Connect phone on selected interface... Check phone mode... Phone in Error mode Seting Local mode... wait... Local mode set Format ... Format Failed All done Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Check phone mode... Phone in Normal mode Seting Local mode... wait... Local mode set Format ... Format Failed All done Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set All On test pattern set - Error Operating mode is OK, no need change... Format ... Format Failed All done Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Check phone mode... Phone in Normal mode Seting Local mode... wait... Local mode set Format ... Format Failed All done Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Check phone mode... Phone in Normal mode Seting Local mode... wait... Local mode set Format ... Format Done All done Phone disconected! Connect phone on selected interface... but card is not working still asking format |
05-16-2014, 17:38 | #12 (permalink) |
No Life Poster Join Date: Feb 2007 Location: pakistan
Member: 456932 Status: Offline Thanks Meter: 53 | 4gb Sd card format failed. i use nokia 5130 phone i try two or three times. Reading Phone Info.... Connected phone - Nokia 5130c-2 Software ver : V 07.95 03-02-10 RM-495 (c) Nokia IMEI : 354317040810509 XappVer : 00000762 DSP Ver : ICPR72_10w01 PPM : V 07.95 03-02-10 RM-495 (c) Nokia MEN CNT : Content: mena_a_red V 07.95 03-02-10 RM-495 (c) Nokia Product SN : HML826840 Product code : 0572162 Base Prd.code: 0567772 Module code : 0204024 Long Prod.SN : 0 Hardware info======= HWID : 1003 Retu : 16 Tahvo : 22 Batery: 3710 mV CMT BT: 2222-302 LCDVer: SEIKO Lock info =========== IMEI : 354317040810509 IMEI spNet : 3A 45 13 07 04 18 50 00 IMEI svNet : 33 45 13 07 04 18 50 40 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Check phone mode... Phone in Normal mode Seting Local mode... wait... Local mode set Format ... Format Failed All done Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone already in Local mode Done! Operating mode is OK, no need change... Format ... Format Failed All done |
