Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2009 Location: india
Member: 1146038 Status: Offline Thanks: 257
| please help me in c3-00 how to read phone book ....? how to read phone book in c3-00 rm-614 my set is only white lcd & vibrate then after few sec. set is off.... *******r say me after open mail create this problem ..... i will try to read phone book via read rpl then set not going local mode .... and also try safe flash but set not going local mode..... now how to read phone book please help me......... thanks advance read rpl...... log Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000009C8F81D6897EB5E2532A593652598B ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.2.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: Reading certificates... Reading NPC certificate... IMEI : 351664053622500 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... - > Phone not found... :( - > CertRead failed : phone was not bootup - > Connection/SW/HW problem, try bootup manually NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351664053622500_CRT_2nd.rpl Phone disconected! Connect phone on selected interface... Code: Core : v1.45 , FlashEngine : v1.40
Selected FlashSettings : SafeFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm614__08.71.mcusw
PPM : rm614__08.71.ppm_mh1
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
EM0 ID: 00005361
ASIC MODE ID: 00
FLIC : 003000EC
Req : XSR 1.6
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:07
ADL: Check mode
Select ASIC [C900]
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Cert Read done!
===Flashing [MCU]===
Erase : Processing rm614__08.71.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm614__08.71.mcusw
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [MCUSW1]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [ISA+DYNSW]
Total writen 528 blocks
TIME : Write time : 00:00:05
MCU Write done
ADL: Request programm status
NAND status : 00000000 / 00000000 / 00000000
===Flashing [PPM]===
Erase : Processing rm614__08.71.ppm_mh1
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm614__08.71.ppm_mh1
Total writen 120 blocks
TIME : Write time : 00:00:01
PPM Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:07
Reboot phone now...
- > AfterFlash Failed! :( Reason : Downgrade try or HW Error
Anyway - try reinsert battery and PowerUp phone manualy
Done!
Elapsed: 00:02:05
Connect phone on selected interface... |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Russia , Syberia Age: 23
Member: 1157320 Status: Offline Sonork: 100.1616907 Thanks: 4,102
| Hello. User Data tab - Read FullFlash After it done - select S40, and select needed - phonebook, galllery, SMS - press GO and select readed file. All done. |
| | #3 (permalink) |
| Code: card found: S/N registered to: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000009C8F81D6897EB5E2532A593652598B ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.2.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:07 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: phone is in flash mode Reading NPC certificate... IMEI : 351664053622500 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351664053622500_CRT_2nd.rpl Will read flash content now... Flash IC Size : 128 MB Read done , 123 MB was readed FullFlash saved to : 351664053622500_full.bin Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 351664053622500.spr ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Done!!! Connect phone on selected interface... Scan image... Disc found, Size: 73M Phonebook file not found :(... Contacts are not found :( Done!!! |
| | #4 (permalink) |
| Code: Scan image... Disc found, Size: 73M Phonebook file not found :(... Contacts are not found :( Done!!! Scan image... Disc found, Size: 73M Phonebook file not found :(... Contacts are not found :( Done!!! Scan image... Disc found, Size: 73M Phonebook file not found :(... Contacts are not found :( Done!!! |
| | #6 (permalink) |
| Hello. Did you select as S40? As I can see - you already flashed CNT into phone or FS is dead fully |
| | #7 (permalink) |
| any way thanks 4 reply but *******r's set is complete with out data lose in nokia care ..... so why not found data our software ....... jst kind 4 info..... i m not lie....! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
