please helpme flash nokia rm-934 deadmode card found: S/N 0099:0118 registered to: chanin Connect phone on selected interface... Core : v1.78 , BB5XG FlashEngine : v8.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm934_13.0.6.mcusw.fls PPM : rm934_13.0.6_059V1G8_s2.rofs.fls CNT : rm934_13.0.6_059V1G8_s2.image.fls Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : A2D04CB2EC7CD900 IF Resp Data : 194200021C030101CAB21009 Wait for user action : Insert battery Sending EBL Loader ... -> Boot fail... Flashing failed... Phone disconected! / log file |
Hello. Charge battery fully. Press Flash button Insert USB cable, insert battery fast. (2-3 second, max - 5 second) Just hold battery little far from contacts and then pull it down, when you hear connection usb device sound in windows. |
Use this pack to install Nokia USB Rom driver http://rapidshare.com/share/AD887298...18BDDFFB215229 |
If they wait ur answer i dont know what happened to them . check the post date before posting else |
can u send flash file for rm 934 |
It inside BEST NaviManager. So, you need have dongle to use it and not waste your and other peoples time here. |
atf box only support this fone |
1000% done nokia 500 rm934 with infinity best ;) history here :cool: card found: S/N CAC1:0122 registered to: rafeek chalingad Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : B4DCD3E2_rm934_14.0.5.mcusw.fls PPM : 0A165ADE_rm934_14.0.5_059S9W9_i1.rofs.fls CNT : 94659C1B_rm934_14.0.5_059S9W9_i1.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 221 [XMM2210 QIMING] IF uCHIPID : 19421109A2E66DEC IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1345.300_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358355052117609 IMEI 2 : 358355052117617 Phone Product Code : 059S9W9 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358355052117609_XG 221_CRT.rpl ===Flashing [MCU]=== Processing file : B4DCD3E2_rm934_14.0.5.mcusw.fls Region count : 2 00 : [ PSI ] : rm934_14.0.5.mcusw.fls.fls 01 : [ Code ] : rm934_14.0.5.mcusw.fls.fls Parse done , flashing now Flash : 00 : rm934_14.0.5.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40000000 , Len : 0x00020000 Erase done Region Start : 0x40000000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done rm934_14.0.5.mcusw.fls.fls image flash done Flash : 01 : rm934_14.0.5.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40040000 , Len : 0x00020000 Erase done Erase area 0x01 , Start 0x40060000 , Len : 0x00160000 Erase done Erase area 0x02 , Start 0x40340000 , Len : 0x02540000 Erase done Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000 Erase done Region Start : 0x40040000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40060000 , Data Len : 0x00160000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40340000 , Data Len : 0x02076490 Region Load done Wait for phone write all data ... Write done rm934_14.0.5.mcusw.fls.fls image flash done ===Flashing [PPM]=== Processing file : 0A165ADE_rm934_14.0.5_059S9W9_i1.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000 Erase done Region Start : 0x42880000 , Data Len : 0x0095F908 Region Load done Wait for phone write all data ... Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : 94659C1B_rm934_14.0.5_059S9W9_i1.image.fls Region count : 1 00 : [ Cust ] : rm934_14.0.5_059S9W9_i1.image.fls.image.fls Parse done , flashing now Flash : 00 : rm934_14.0.5_059S9W9_i1.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x021E0000 Region Load done Wait for phone write all data ... Write done rm934_14.0.5_059S9W9_i1.image.fls.image.fls image flash done Flashing done! Total flash time : 00:02:00 Reboot phone now... Reading Phone Info.... Connected phone - 500 Software Info: V 14.0.5 21-04-14 RM-934 (c) Nokia IMEI: 358355052117609 PPM version : b5788952fbca441e849af95026bca5f278c00658 Product code: 059S9W9 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:51 Connect phone on selected interface... |
