11-16-2012, 14:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 64
Member: 70663 Status: Offline Thanks Meter: 6 | plz help me help me plz Login: 0318A83C7A Using F-bus count... Sending code 972061756943770 Level : 7 to SimLock Server... Simlock Server Answer: Bad Code... Done! after more than a week no response I contacted your service answer:Try to enter code manually: #pw+972061756943770+7# same result and he told me to contaté this address contact to [email protected] but no answer Here are the files againblc.rar thank you for your help |
11-16-2012, 14:29 | #2 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
11-16-2012, 21:56 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 1. reset phone to factory defaults 2. try to enter code manually again 3. if still no luck try to enter that codes (start from 7th code) #pw+364444701546709+1# #pw+892201318699684+2# #pw+024927310328896+3# #pw+527427871623311+4# #pw+175027072692326+5# #pw+427776001210763+6# #pw+185143898538793+7# |
11-17-2012, 08:43 | #10 (permalink) |
Member: 70663 Status: Offline Thanks Meter: 6 | Reading Phone Info.... Connected phone - Nokia C2-01 Software ver : V 11.20 27-10-11 RM-721 (c) Nokia IMEI : 359075047426316 DSP Ver : SPR91_09w09_11w02 PPM : V 11.20 27-10-11 RM-721 (c) Nokia MEA CNT : Content: meaa_059D649 V 11.20 27-10-11 RM-721 (c) Nokia Product SN : 4BB485AAH Product code : 059G527 Base Prd.code: 059C872 Module code : 0204769 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 51 Tahvo : 00 Batery: 4173 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 359075047426316 IMEI spNet : 3A 95 70 05 74 24 36 01 IMEI svNet : 33 95 70 05 74 24 36 71 F3 Conf key : 8000000000000000 Provider key : 2342000000000000 Country : United Kingdom Operator : 3 UK Counters : Key 3 [3] , Fbus 3 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] |
11-17-2012, 11:03 | #14 (permalink) |
Member: 70663 Status: Offline Thanks Meter: 6 | Using F-bus count... Sending code 364444701546709 Level : 1 to SimLock Server... Simlock Server Answer: Bad Code... Done! Using F-bus count... Sending code 892201318699684 Level : 2 to SimLock Server... Simlock Server Answer: Bad Code... Done! |
