08-26-2015, 13:39 | #4 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Quote: Remove Smart-Card from Card-reader Clecn Smart-Card contacts Insert Card back Also you can try to insert Card into another Card-reader | |
08-26-2015, 15:47 | #5 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Barisal, Bangladesh Age: 34
Member: 928938 Status: Offline Sonork: 100.1648034 Thanks Meter: 41 | Dear YellowBoss Sir At last I found It's smart card problem, but how I clean it? If I change my smart card to another card reader/dongle then another card reader/dongl also stop working. How I fix it? |
08-26-2015, 20:05 | #6 (permalink) | |
Sorry I did not understand well. Do you mean that Smart-card is damaged or what ? If Smart-Card become dead (PC can not detect it) the only way is - new Smart-Card. If Smart-Card can be detected by PC - we can repair it by re-programming. | |
08-27-2015, 03:53 | #7 (permalink) | |
Member: 928938 Status: Offline Sonork: 100.1648034 Thanks Meter: 41 | Quote:
How I understood that my Smart-Card is dead? image upload Last edited by anirbanprince; 08-27-2015 at 04:02. | |
08-27-2015, 08:42 | #8 (permalink) | |
Member: 928938 Status: Offline Sonork: 100.1648034 Thanks Meter: 41 | Quote: Database: ./FSCard.ini Card-Reader: Alcor Micro USB Smart Card Reader 0 ATR: 3B7D95000080318065B0831148C883009000 Historical ATR bytes: 0080318065B0831148C8830090 Card Manager: A000000018434D00 SerialNumber: 0100616D ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3172 Serial Number: 0100616D Batch Identifier: 1C6A Module Fabricator: 1292 Module Packaging Date: 5060 IC Card Manufacturer: 5003 IC Em******* Date: 5060 Pre Personalizer: 5004 Pre Personalization Date: 5060 Pre Personalization Equipment Identifier: 00000084 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0100616D1C6A1292 GP Version: 2.1.1 SCP Version: 1, Option: 5 | |
08-27-2015, 09:04 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @anirbanprince Hello, 1. Update your Card-Reader Drivers: Drivers - http://server1.infinity-box.com/down...T2K_x32_x64.7z Instruction - http://server1.infinity-box.com/down...er_drivers.pdf Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager - Select [BEST] at bottom of page instead of "Autodetect" - Update Dongle firmware |
08-27-2015, 12:05 | #10 (permalink) | |
Stil same problem | |
