Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 03-23-2012, 15:34   #1 (permalink)
Wasim007's Avatar
Member: 500302
Thanks Meter: 157
Arrow possible nokia 101 imei repair ????????????
card found: S/N #######
registered to: was####
Connect phone on selected interface...
UFS S/N 78### boot - Ok
Phone found!
Series 40 Device detected!
read info... - Ok
Reading Phone Info....
SW ver : V 06.30 03-09-11 RM-769 (c) Nokia
IMEI : ????????0000000
PPM : V 06.30
03-09-11
RM-769
(c) Nokia
MG
PCode :
BPCode :
HWID :
LCDVer : TPO:BARACOAv90
HX5081
Sl Conf : 000-00-00000000000
Sl Prof : 000000000004000-0
Sl Aux : 000B0000
Hw Sig : FE84159D4EA81FAB
Provider : Damaged SL!
Lock info:
Done!
Core : v1.42 , FlashEngine : v1.25
Selected FlashSettings : FullFlash
Files Set for Flashing :
MCU : rm769_006.650
PPM : rm769_006.65mi
CNT : rm7690_nai06.65mi_nlt
Infineon flashing...
-> Infineon XG110 : Failed read IMEI backup...
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH ID : 0020000000048800
FLASH ID : UNKNOW [Not In Base]
Boot Done!
===Flashing [MCU]===
File : rm769_006.650
Image : hw_f3_rm769_r06.650.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00000000 , Len : 0x00020000
Erasing, wait ...
Erase done
Write , Start : 0x00000000 , Len : 0x00006000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00800000 , Len : 0x00400000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x003F0000
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00C5D000 , Len : 0x00203000
Erasing, wait ...
Erase done
Write , Start : 0x00C5D000 , Len : 0x0019E700
Flashing , wait ...
Region flash done
Check : 5824
===Flashing [PPM]===
File : rm769_006.65mi
Image : hw_f3_rm769_006.65mi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00100000 , Len : 0x00700000
Erasing, wait ...
Erase done
Write , Start : 0x00100000 , Len : 0x0051EB80
Flashing , wait ...
Region flash done
Check : B9D5
===Flashing [CNT]===
File : rm7690_nai06.65mi_nlt
Image : hw_f3_rm7690_nai06.65mi_nlt.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00E60000 , Len : 0x00100000
Erasing, wait ...
Erase done
Write , Start : 0x00E60000 , Len : 0x000EA140
Flashing , wait ...
Region flash done
Check : 2071
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Init Service mode... Wait...
Afterflash settings...
SW ver : V 06.65
07-11-11
RM-769
(c) Nokia
PCode :
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
All done!
Phone found!
read info... - Ok
SW ver : V 06.65 07-11-11 RM-769 (c) Nokia
PPM : V 06.65
07-11-11
RM-769
(c) Nokia
MI
PCode :
BPCode :
HWID :
HX5081
Sl Aux : 000B0000
Lock info:
Done!
The Following User Says Thank You to Wasim007 For This Useful Post:
Old 03-23-2012, 15:51   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Do you have any PM backup?
The Following User Says Thank You to Dzirt For This Useful Post:
Old 03-23-2012, 15:57   #3 (permalink)
Wasim007's Avatar
Member: 500302
Thanks Meter: 157
no no backup pm,rpl.....................................
Old 03-23-2012, 16:15   #4 (permalink)
pawans's Avatar
Member: 346345
Sonork: jhon18
Thanks Meter: 56
if you have no back up rpl no solution... replace infenion chips and flash chips from scrap n101 board to work again your phone...
The Following 2 Users Say Thank You to pawans For This Useful Post:
Old 03-23-2012, 16:17   #5 (permalink)
Member: 1732968
Thanks Meter: 5
there is no any solution still wait may be in future possible.
The Following User Says Thank You to kmdworld05 For This Useful Post:
Old 06-04-2012, 16:54   #6 (permalink)
SR9
SR9's Avatar
Member: 957066
Sonork: 100.1658197
Thanks Meter: 642
i have pm back up how can i?
The Following User Says Thank You to SR9 For This Useful Post:
Old 06-04-2012, 17:40   #7 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Hello
Write back Pm , all will be Ok then
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 08-16-2012, 08:03   #8 (permalink)
Member: 765949
Thanks Meter: 2
101 imei curepted help me
The Following User Says Thank You to shinemp For This Useful Post:
Old 08-16-2012, 19:36   #9 (permalink)
allttar's Avatar
Member: 136220
Thanks Meter: 407
nokia 101 gold = sl3
no support repaire imei all box
The Following User Says Thank You to allttar For This Useful Post:
Old 10-17-2013, 08:35   #10 (permalink)
Member: 1588882
Sonork: 9848653616
2700 c network problem pls help me
The Following User Says Thank You to sai8352 For This Useful Post:
Old 10-19-2013, 06:28   #11 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
posibal with atf............
The Following User Says Thank You to ARIF GIGANI For This Useful Post:
Old 10-19-2013, 08:52   #12 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
How much will be monkeys here? Stupid monkeys >_<
Old 10-19-2013, 08:59   #13 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,219
only possible with hardware change cpu if u can..only solution till now
The Following User Says Thank You to gsm mithun roy For This Useful Post:
Old 10-19-2013, 20:41   #14 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
@all
answer already given by Dzrit , possible by restore pm or by hardware . please don't spam around here .
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 10-28-2013, 15:37   #15 (permalink)
Member: 1680321
Thanks Meter: 4
halp sir
nokia x1-01 imei ??????????????4 sow
Read and Check phone data...
Infineon checking...
Sync Ok , A2
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
EPP CFG [Bering]...
Boot Done!
Done!
Phone found!
read info... - Ok
SW ver : V 05.39 01-09-11 RM-713 (c) Nokia
PPM : V 05.39
01-09-11
RM-713
(c) Nokia
MG
PCode :
BPCode :
HWID :
LCDVer : AUO:BARACOAv83
NT39121
Sl Aux : 000B0000
Hw Sig : 1DC59C96DA3C0E45
Country : Unknown
Operator : Unknown
Lock info:
Done!
Backup Certificates now...
Setting FlashMode
FlashMode set Ok
No answer from phone...
- > 1. Check cable/connection, try again
- > 2. Maybe HW fault or bad cable
Phone found!
read info... - Ok
The Following User Says Thank You to saptam For This Useful Post:
Page generated in 0.22876 seconds with 10 queries
