Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1546 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: INDONESIA
Member: 1210129 Status: Offline Thanks: 706
| LANGUAGE 5610 BI Connect phone on selected interface... UFS S/N 73751 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Files Set for Flashing : PPM : rm242__09.40.ppm_x Check FlashFiles, Please, wait... -> SWversion check skipped : Custom mode selected Backup enabled, Will read Certificates now... CRT308 Backup Created... ![]() Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1960010AB6E87D56C27A6FC7C17D7AF4B6741DB9 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 7EB2973C70788F43BFADFB1AD46A77E51DF8DB0900 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 354854023906763 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354854023906763.rp l Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1960010AB6E87D56C27A6FC7C17D7AF4B6741DB9 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 7EB2973C70788F43BFADFB1AD46A77E51DF8DB0900 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm242__09.40.ppm_x Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01600000 - 0x01CBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:20 Transmission mode : Dual (Ddr, TX2) Write : Processing rm242__09.40.ppm_x Total writen 406 blocks TIME : Write time : 00:00:43 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5610d-1 Software Info: V 09.40 07-11-08 RM-242 (c) Nokia IMEI: 354854023906763 Product code: 0564237 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 19 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... |
| The Following 3 Users Say Thank You to rizkypratama999 For This Useful Post: |
| | #1547 (permalink) |
| 7310c NOKIA ONLY card found: S/N XXXX:XXXX registered to: rizky pratama Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm379__09.40.mcusw PPM : rm379__09.40_PPM_X.ppm_x CNT : rm379__09.40_IMAGE_X.image_x Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 12D0011425047D567558116D283165804C10360E CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm379__09.40.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x010DFFFF, NOR, CMT Result: 0000 Erasing area 0x010E0000 - 0x0121FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:54 Write : Processing rm379__09.40.mcusw Total 1108 [1108/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm379__09.40_PPM_X.ppm_x Found 1 areas to erase Erasing area 0x01220000 - 0x018BFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:20 Write : Processing rm379__09.40_PPM_X.ppm_x Total 407 [407/0/0] blocks to write, writing... TIME : Write time : 00:00:45 PPM Write done ===Flashing [CNT]=== Erase : Processing rm379__09.40_IMAGE_X.image_x Found 2 areas to erase Erasing area 0x018C0000 - 0x01B3FFFF, NOR, CMT Result: 0000 Erasing area 0x01B40000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:03 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm379__09.40_IMAGE_X.image_x Total 880 [880/0/0] blocks to write, writing... TIME : Write time : 00:01:27 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:07:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 7310 Supernova Software Info: V 09.40 06-11-08 RM-379 (c) Nokia IMEI: 356828023894805 PPM version : V 09.40 06-11-08 RM-379 (c) Nokia X Product code: 0564997 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:08:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
| | #1548 (permalink) |
| 3110C RESTART card found: S/N XXXX:XXXX registered to: rizky pratama Connect phone on selected interface... UFS S/N 73751 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Files Set for Flashing : CNT : rm237__07.21.image_x Check FlashFiles, Please, wait... -> SWversion check skipped : Custom mode selected Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... ![]() CRT308 Backup Created... ![]() Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1BB0011772977D561101EA9F557EF4EA7BEA0122 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 359343025242323 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\359343025242323.rp l Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1BB0011772977D561101EA9F557EF4EA7BEA0122 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.21.image_x_128 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01FDFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:27 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.21.image_x_128 Total writen 360 blocks TIME : Write time : 00:00:40 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 359343025242323 Product code: 0514959 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone already in Test mode, skip change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:01 |
| | #1549 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: Pakistan " Karachi " Age: 31
Member: 572216 Status: Online Sonork: 100.1612300 Thanks: 960
| registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm411__07.23.image_mb_grey Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created... ![]() SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\356840021602262_SIM. rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 09D0000112E658501B656D1B0AE0E2BFA6EEECF3 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: D93826B23E9B093BE4DD7304FBAA6778996AE60B Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm411__07.23.image_mb_grey ConvertImage: Page Size is 128K, no need convert Loader len: 307008, CHK: C0CE ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm411__07.23.image_mb_grey Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:06 Write : Processing rm411__07.23.image_mb_grey Total 520 [520/0/0] blocks to write, writing... TIME : Write time : 00:00:34 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:41 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5220 XpressMusic Software Info: V 07.23 17-07-09 RM-411 (c) Nokia IMEI: 356840021602262 PPM version : V 07.23 17-07-09 RM-411 (c) Nokia MB Product code: 0564105 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:31 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
| The Following 3 Users Say Thank You to saeedullah_khan For This Useful Post: |
| | #1550 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading User code... User Code is: 4275637 Done! Resetting User Code to default (12345)... Clear data : Ok Result: 12345 Done! Backup Certificates now... Backup CRT308 data... CRT308 Backup Created... ![]() Check communication with phone.... ADL not support backup mode, rpl reading impossible SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\353101023907867_SIM. rpl Elapsed: 00:00:00 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
| | #1551 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_ora_pl_games Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 1E8002118D727E5694B7359842CAF49340046789 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:06 Write : Processing rm237__07.30.mcusw Total 945 [945/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:00:47 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:37 Write : Processing rm237__07.30.ppm_c Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:12 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.30.image_ora_pl_games Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:54 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 253888, CHK: 17DB ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Write : Processing rm237__07.30.image_ora_pl_games_128 Total 296 [296/0/0] blocks to write, writing... TIME : Write time : 00:00:15 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:53 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 353203036848383 PPM version : V 07.30 07-05-09 RM-237 (c) Nokia. C Product code: 0544318 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:42 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! |
| | #1552 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-504_32.0.007_prd.core.C00 PPM : RM-504_32.0.007_prd.rofs2.V12 PPM2 : RM-504_32.0.007_C06_prd.rofs3.fpsx CNT : RM-504_32.0.007_007_000_U001.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... ![]() SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\359368034641819_SIM. rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3695 mV -> Batery voltage less, than 3,8V (3695mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 12A00008948E0052F31C8DBD6935074EB87BD398 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing UPDAPP... Processing PAPUBKEYS... Processing UPDAPP... Boot Done! ![]() TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-504_32.0.007_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-504_32.0.007_prd.core.C00 Total 434 [434/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:34 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-504_32.0.007_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x07260000 - 0x0935FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_32.0.007_prd.rofs2.V12 Total 84 [84/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:07 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-504_32.0.007_C06_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09360000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_32.0.007_C06_prd.rofs3.fpsx Total 27 [27/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-504_32.0.007_007_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_32.0.007_007_000_U001.uda.fpsx Total 25 [25/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5530 XpressMusic Software Info: V ICPR72_10w25.3 11-10-10 RM-504 (c) Nokia IMEI: 359368034641819 Ape Version: V 32.0.007 Product code: 0578172 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:01:12 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
| | #1553 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 82121 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Files Set for Flashing : PPM : rm689_003.00ic Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000542200 FLASH ID : Samsung, K8S6415E Boot Done! ===Flashing [PPM]=== File : rm689_003.00ic Image : hw_s01_rm689_003.00ic.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x001E8980 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001E8980 Flashing , wait ... Region flash done Check : CB69 Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 03.00 31-08-10 RM-689 (c) Nokia IMEI : 354863047099364 PCode : 059B372 All done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
| | #1554 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6233 Software ver : V 05.60 14-09-07 RM-145 (c) Nokia IMEI : 356293015404966 Ape Ver : APE Var : APE ADSP: DSP Ver : pb05wk46v50 APE Test: PPM : V 05.60 14-09-07 RM123_145_- (c) Nokia C CNT : Product SN : 2AG901923 Product code : 0532188 Base Prd.code: 0528588 Module code : 0202772 Long Prod.SN : Hardware info======= HWID : 1016 Retu : 32 Tahvo : 53 Batery: 3976 mV Camera: CMT BT: APE BT: APE HW: LCDVer: SEIKO RF ic : Lock info =========== IMEI : 356293015404966 IMEI spNet : 3A 65 92 03 51 04 94 06 IMEI svNet : 33 65 92 03 51 04 94 06 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created... ![]() User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading User code... User Code is: 12345 Done! Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm123_145_30005.60.image_g Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created... ![]() Getting product info... RAP_BOOT: 0803000002010000 RAP_PUBLIC: 212002129157635085A1F52F258BEF2AEDBE4241 CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: 2F36DDC4990FD844712A61A80C033211BD9602E3 Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 236992, CHK: 0254 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! ===Flashing [CNT]=== Erase : Processing rm123_145_30005.60.image_g_128 Found 2 areas to erase Erasing area 0x016E0000 - 0x01E7FFFF, NOR, CMT Result: 0000 Erasing area 0x01E80000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:26 Write : Processing rm123_145_30005.60.image_g_128 Total 128 [128/0/0] blocks to write, writing... TIME : Write time : 00:00:11 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:00:37 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6233 Software Info: V 05.60 14-09-07 RM-145 (c) Nokia IMEI: 356293015404966 PPM version : V 05.60 14-09-07 RM123_145_- (c) Nokia C Product code: 0532188 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:00:58 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
| | #1555 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm303__10.10.mcusw PPM : rm303__10.10.ppm_m4 CNT : rm303__10.10.image_m4_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 2AA0011270700254C99F84856788A241DF46FF7E CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm303__10.10.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x010DFFFF, NOR, CMT Result: 0000 Erasing area 0x010E0000 - 0x0121FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:01 Write : Processing rm303__10.10.mcusw Total 1107 [1107/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:51 MCU Write done ===Flashing [PPM]=== Erase : Processing rm303__10.10.ppm_m4 Found 1 areas to erase Erasing area 0x01220000 - 0x0189FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:15 Write : Processing rm303__10.10.ppm_m4 Total 314 [314/0/0] blocks to write, writing... TIME : Write time : 00:00:33 PPM Write done ===Flashing [CNT]=== Erase : Processing rm303__10.10.image_m4_red Found 2 areas to erase Erasing area 0x018A0000 - 0x01B1FFFF, NOR, CMT Result: 0000 Erasing area 0x01B20000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:00 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm303__10.10.image_m4_red Total 512 [512/0/0] blocks to write, writing... TIME : Write time : 00:00:47 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5310 XpressMusic Software Info: V 10.10 23-03-09 RM-303 (c) Nokia IMEI: 359562017262276 PPM version : V 10.10 23-03-09 RM-303 (c) Nokia M4 Product code: 0556708 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:07:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created... ![]() Check communication with phone.... ADL not support backup mode, rpl reading impossible SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\359562017262276_SIM. rpl Elapsed: 00:00:00 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
| | #1556 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 82121 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok User ACCEPTED FULL ERASE Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 167001161B807E5635FC204941E3B5E3EA4975CE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x03FFFFFF Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... Erase CMT Finished , [FF] CMT : Erase Ok Done Phone disconected! Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : 4BB8AA07_rm495__07.97.ppm_mena_a1 CNT : E24393CE_rm495__07.97.image_mena_a1_red Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 167001161B807E5635FC204941E3B5E3EA4975CE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 0 byte(s) CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) No any CRT data (MCU damaged/CERT erased), skip saving Init Service mode... Wait... Init Service Mode Failed! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 167001161B807E5635FC204941E3B5E3EA4975CE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing C5F02102_rm495__07.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:05 Transmission mode : Dual (Ddr, TX2) Write : Processing C5F02102_rm495__07.97.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1169 blocks TIME : Write time : 00:02:43 Transmission mode : Dual (Ddr, TX2) Erase : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 Transmission mode : Dual (Ddr, TX2) Write : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1 Total writen 388 blocks TIME : Write time : 00:00:51 ConvertImage: Processing E24393CE_rm495__07.97.image_mena_a1_red ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:08 Transmission mode : Dual (Ddr, TX2) Write : Processing E24393CE_rm495__07.97.image_mena_a1_red Total writen 656 blocks TIME : Write time : 00:01:30 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 12345610654321? Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! ![]() SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! Backup Certificates now... Backup CRT308 CRT308 Backup Created... ![]() CRT308 Backup Created... ![]() Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 167001161B807E5635FC204941E3B5E3EA4975CE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 000000000000000 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\000000000000000_SIM. rpl Connect phone on selected interface... Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! |
| | #1557 (permalink) |
| registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.21.mcusw PPM : rm237__07.21.ppm_mea4 CNT : rm237__07.21.image_mea4 Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... ![]() Batery valtage : 3792 mV -> Batery voltage less, than 3,8V (3792mV). Continue at user risk Getting product info... RAP_BOOT: 0901010002010000 RAP_PUBLIC: 0E70011336F97E566219240192BCCF3A6130728B CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: C0E691EA16A7593A9BB28832D7312A39F7ED668D Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k DownGr: Prepare phone for downgrade... DownGr: Prepare Started.... Psec : 12704 -> Prepare status : Ok DownGr: Phone ready! Loader len: 253888, CHK: 129B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data NOT accepted by phone, continue at user risk ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:17 Write : Processing rm237__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:01 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.21.ppm_mea4 Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:40 Write : Processing rm237__07.21.ppm_mea4 Total 178 [178/0/0] blocks to write, writing... TIME : Write time : 00:00:12 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.21.image_mea4_128 Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:58 Write : Processing rm237__07.21.image_mea4_128 Total 212 [212/0/0] blocks to write, writing... TIME : Write time : 00:00:14 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:23 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 356029035287704 PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. MEA Product code: 0544343 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:07:11 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
| | #1558 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Online Thanks: 433
| nokia 5220 rm-411 flashed successfully using j.a.f nokia 5220 rm-411 flashed successfully using j.a.f Code: Opening Connection... Device Location: 00000041 Connect Ok! Initializing Connection... JAF Firmware: 01.B1 JAF S/N DiTENZSF boot - Ok Connect phone on selected interface... Ready for operations... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm411__07.23.mcusw PPM : rm411__07.23.ppm_mr CNT : rm411__07.23.image_mr_in_red Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 219000166B505750B429D8CB357B2FAAD43E1B81 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000000000 CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Boot done! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm411__07.23.mcusw Init Erase Mode Ok Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:46 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm411__07.23.mcusw Init Write Mode Ok CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1280 blocks TIME : Write time : 00:02:35 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm411__07.23.ppm_mr Init Erase Mode Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:31 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm411__07.23.ppm_mr Init Write Mode Ok Total writen 461 blocks TIME : Write time : 00:00:54 PrReq : NOR, 00 ConvertImage: Processing rm411__07.23.image_mr_in_red ConvertImage: Page Size is 128K, no need convert TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm411__07.23.image_mr_in_red Init Erase Mode Ok Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:03:22 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm411__07.23.image_mr_in_red Init Write Mode Ok Total writen 632 blocks TIME : Write time : 00:01:14 PrReq : NOR, 00 Switch jaf to FBUS... FbusMode set Ok Phone connected IMEI : 353662017872342 Simlock status : Simlock is Ok Security status : Security is Ok Settings After Flash Defaults... FullFactorySet...OK! Flashing done |
| The Following 3 Users Say Thank You to sunny_luthras99 For This Useful Post: |
| | #1559 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks: 93
| 6131 Dead USB Flashing Success! card found: S/N 012345678 registered to: xerraco Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm115__06.60.mcusw PPM : rm115__06.60.ppm_t CNT : rm115__06.60.image_tw Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 2360000992AE6C56E20D500E94343B1A7A8CCFD2 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm115__06.60.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x002DFFFF, NOR, CMT Result: 0000 Erasing area 0x002E0000 - 0x00EDFFFF, NOR, CMT Result: 0000 Erasing area 0x00EE0000 - 0x00EF7FFF, NOR, CMT Result: 0000 Erasing area 0x00EF8000 - 0x00EFFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:03 Write : Processing rm115__06.60.mcusw Total 852 [852/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:11 MCU Write done ===Flashing [PPM]=== Erase : Processing rm115__06.60.ppm_t Found 1 areas to erase Erasing area 0x00F00000 - 0x0145FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:22 Write : Processing rm115__06.60.ppm_t Total 309 [309/0/0] blocks to write, writing... TIME : Write time : 00:00:26 PPM Write done ===Flashing [CNT]=== Erase : Processing rm115__06.60.image_tw Found 1 areas to erase Erasing area 0x01460000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:57 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm115__06.60.image_tw ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 254784, CHK: 0CD7 ADL -> Sending loader... Reset connection... Write : Processing rm115__06.60.image_tw_128 Total 408 [408/0/0] blocks to write, writing... TIME : Write time : 00:00:33 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:34 Reboot phone now... |
| The Following 3 Users Say Thank You to xerraco For This Useful Post: |
| | #1560 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: punjab(india) Age: 34
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks: 225
| nokia 7210c flashing done card found: S/N 0390:0118 registered to: jindalgsm4255 Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_c CNT : rm436__07.23.image_c_de Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 25B001072705595013824FBCF0503B883FDA0031 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm436__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0119FFFF, NOR, CMT Result: 0000 Erasing area 0x011A0000 - 0x0133FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:48 Write : Processing rm436__07.23.mcusw Total 1170 [1170/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:54 MCU Write done ===Flashing [PPM]=== Erase : Processing rm436__07.23.ppm_c Found 1 areas to erase Erasing area 0x01340000 - 0x01BDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:49 Write : Processing rm436__07.23.ppm_c Total 448 [448/0/0] blocks to write, writing... TIME : Write time : 00:00:21 PPM Write done ===Flashing [CNT]=== Erase : Processing rm436__07.23.image_c_de Found 2 areas to erase Erasing area 0x01BE0000 - 0x01F7FFFF, NOR, CMT Result: 0000 Erasing area 0x01F80000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:25 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm436__07.23.image_c_de Total 1424 [1424/0/0] blocks to write, writing... TIME : Write time : 00:01:07 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 359310021540968 PPM version : V 07.23 17-07-09 RM-436 (c) Nokia C Product code: 0572571 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:11:36 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok ![]() ![]() |
| The Following 3 Users Say Thank You to JINDALGSM™ For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-09-1999 17:04 |
