01-28-2014, 10:10 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Problem in extracting Contacts C2-06... With Best it says Code: BackUp UserData : [PhoneBook] Generation mode : [S40] === Cnt Server Info === Used : 266 records [1000] Free : 734 records [1000] Total : 1000 records === Cnt Server Info === Scanning FileSystem ... Setting mode #2 Read done ;) Done... Reading full flash method Code: Executing Dump Read Check communication with phone.... Communication verify done... Preparing... Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_2.5_M1S1 Boot done! Reading Done! Saved to : 35XXXXXXXXXXXX_X213.bin ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== ===== MMC PASSWORD ===== We have next Pass: [space]gt. ===== MMC PASSWORD ===== ===== RPL DATA ===== Executing RPL Data extraction... SL3 Simlock found (XGOLD) ... WMDRM Key found ... IMEI 1 : 35XXXXXXXXXXXX IMEI 2 : 35XXXXXXXXXXXX NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35XXXXXXXXXXXX_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Open file "C:\InfinityBox\BEST\Phones_Data\Readout\35XXXXXXXXXXXX_X213.bin" - Ok Search... Contacts are not found :( Contacts not found Done!!! Open file "C:\InfinityBox\BEST\Phones_Data\Readout\35XXXXXXXXXXXX_X213.bin" - Ok Search... Contacts are not found :( Contacts not found Done!!! Thanks |
01-28-2014, 10:54 | #3 (permalink) |
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Tried different modes too, but it fails!!! Code: With -- Xgold213 ----------------------------- Open file "C:\InfinityBox\BEST\Phones_Data\Readout\35XXXXXXXXXXXX_X213_OLD.bin" - Ok Prepare... Scan image... Disc found, Size: 24M Phonebook not found :( Contacts are not found :( Done!!! ------------------------------ With Seris40/XG618 Forensic ---------------------------------------------- Processing S40 / XG618 Forensic mode [FDCL] : 0x00000000 Done!!! |
01-28-2014, 11:39 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Had check the file - most of data smashed. Will be greeat, if I can recover from it near 50-90 alive contacts. May be more, may be less. Take 1-2 days. Add in sw also after. |
